    Need for homing after print finishes
    • AlexLin
      AlexLin last edited by
      Hi
      Why do I always have to home all my axis after a print finishes. Is this by design or due to my M84 in my End G-Code? Or is this behaviour specified in a system g-file?
      • adavidm
        adavidm last edited by
        AFAIK M84 (Stop Idle Hold) will release the motors and invalidate the homing for the given axis (or all axes if none specified).
        Probably the easiest fix is to remove your M84. RepRepFirmware will use 30% of the max current to maintain position when the axes are not moving. You can alter this percentage in config.g if required with M906
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents.
        adavidm
        AlexLin 1 Reply Last reply Reply Quote 0
        • AlexLin
          AlexLin @adavidm last edited by
          @adavidm thanks
