    Cannot get the print fan to come on
    • sparkymark79
      sparkymark79 last edited by
      Anycubic Delta Linear + with duet 3d and smart effector
      I can't for the life of me get the print fan to come on. I've unplugged it and held it against the 'always on' connectors and the print fan springs to life so i know it's not broken
      I currently have the hot end fan plugged into P0, and the print fan connected to P1. Is it my settings. Is my Duet3d connection broken. If I had hair I'd be pulling it out. Here's the important bit out of my config.g:
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P1 D0 H1 ; tool 0 uses extruder 0, heater 1 (and fan 1)
      M501
      thanks
        dc42 administrators @sparkymark79 last edited by
        @sparkymark79 said in Cannot get the print fan to come on:
        You have both fans set to thermostatic control.
        Our intention is that you use Fan 0 for the print cooling fan and Fan 1 for the heatsink fan. This is easiest to set up in firmware, and is how the firmware uses the fans by default.
