    Invert logic output H3
    • flopo76
      flopo76 last edited by flopo76
      Hi,is there a way to invert signal output on H3 (heather3). Now i have M3 S255 and my laser is off and on with M3 S0. I need to invert,but how?
      Thanks
        If you are using M452 to put the machine to laser mode, and you are using the P parameter in that command to set the pin for the M3 command, then you can also use the I1 parameter to invert the output. Looks like I forgot to document it in the GCodes wiki page.
        • flopo76
          @dc42 said in Invert logic output H3:
          I1
          Yes,work.Thanks.
