Mesh Grid Compensation
Did you set you Z by "Home Z" or do you adjust with a piece of paper and G92 Z0?
I might be wrong but if your home Z and your offset isn't setup, that could cause the issue if before running M92 you your whole M92 should be off.
I will explain, if you home with your probe and your 0 is really 3mm, you then home with a piece of trigger and fix the difference but that will cause that when you run M92 and your probe triggers, they will assume that your are always minimun 3mm off...
@nylkos
how do i set the offset? -
What type of Z probe are you using?
uxcell LJ12A3-4-Z/AX 3-Wire DC6-36V 300mA NPN NC 4mm Inductive Proximity Sensor Switch https://www.amazon.com/dp/B00S50O152/ref=cm_sw_r_cp_api_OUWEBb2TQTHR5 -
You can find your trigger height with this
Please post your complete config.g, homeall.g and homez.g files, and tell us how you have connected the inductive sensor to the Duet.
Sorry for the late responseand the way i have it hooked up is its Positive and negative wires are hooked up to the 12v power supply because it needs at least 6 volts i think and then its other wire going to the z probe input.
I'm sorry for the delay in looking at this, things are hectic right now with new firmware development.
I'm sorry it has taken me so long to look at this. Does your printer still have this problem?
If so, then I can think of a these possible explanations:
- The Z motor is consistently skipping steps when moving in one direction, but not when moving in the other direction. To test this, home the printer, position the nozzle at a known height above the bed, then send these commands:
G91 ; relative mode
G1 Z15 F100
G1 Z-15 F100
G1 Z15 F100
G1 Z-15 F100
... (repeat that pair of commands several times)
G90 ; back to absoluteThen check whether the nozzle height above the bed is the same as when you started.
The print head is crashing into the bed before the Z probe triggers, causing missed steps at that point.
The sudden stop that occurs during bed probing is causing the missed steps. To check this, position the head over the bed but above the trigger height and send these two commands repeatedly:
G30 S-1
G1 Z10
G30 S-1
G1 Z10
...The trigger height reported by the G30 S-1 command should remain the same to within about 0.02mm. Does it?
HTH David
