    Duet Wifi interface suddenly stopped working
    • divvet
      divvet last edited by
      Hi there,
      I have been running my duet for months without issue, a couple of days ago I run a print fine, come to set up a print today but I am unable to connect to the wifi interface.
      Everything seems to be reporting fine on the duet, the m122 command shows :
      12:00:25.050 : === Diagnostics ===
      12:00:25.050 : RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.0 or 1.01
      12:00:25.050 : Board ID: 08DAM-999TL-MQ4SD-6J1FA-3SJ6P-959MW
      12:00:25.050 : Used output buffers: 1 of 20 (11 max)
      12:00:25.050 : === RTOS ===
      12:00:25.050 : Static ram: 28476
      12:00:25.050 : Dynamic ram: 96236 of which 0WiFi: Conn 1: free
      12:00:25.050 : recycled
      12:00:25.050 : Exception stack ram used: 316
      12:00:25.050 : Never used ram: 6044
      12:00:25.050 : Tasks: NETWORK(ready,1112) HEAT(blocked,1248) MAIN(running,3484)
      12:00:25.050 : Owned mutexes:
      12:00:25.050 : === Platform ===
      12:00:25.050 : Last reset 00:32:49 ago, cause: reset button or watchdog
      12:00:25.050 : Last software reset at 2018-08-14 23:21, WiFi: Conn 2: free
      12:00:25.050 : reason: User, spinning module GCodes, available RAM 5656 bytes WiFi: Conn 3: free
      12:00:25.050 : (slot 1)
      12:00:25.050 : Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0xffffffff
      12:00:25.050 : Error status: 0
      12:00:25.050 : Free file entries: 9
      12:00:25.050 : SD card 0 detected, interfWiFi: Conn 4: free
      12:00:25.051 : WiFi: Conn 5: free
      12:00:25.051 : ace speed: 20.0MBytes/sec
      12:00:25.051 : SD card longest block write time: 0.0ms, max retries 0
      12:00:25.051 : MCU temperature: min 38.4, current 38.8, max 39.1
      12:00:25.051 : Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0
      12:00:25.052 : Driver 0: standstill, SG miWiFi: Conn 6: free
      12:00:25.052 : n/max not available
      12:00:25.052 : Driver 1: standstill, SG min/max not available
      12:00:25.052 : Driver 2: standstill, SG min/max not available
      12:00:25.052 : Driver 3: standstill, SG min/max not available
      12:00:25.052 : Driver 4: standstill, SG min/max not available
      12:00:25.052 : Date/time: 1970-01-01 00:00:00
      12:00:25.052 : Slowest loop: 20.WiFi: Conn 7: free
      12:00:25.052 : 06ms; fastest: 0.08ms
      12:00:25.052 : === WiFi:
      12:00:25.052 : Move ===
      12:00:25.052 : Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      12:00:25.052 : Scheduled moves: 0, completed moves: 0
      12:00:25.052 : Bed compensation in use: none
      12:00:25.052 : Bed probe heights: 0.000 0.000 0.000 0.000 0.000
      12:00:25.052 : === Heat ===
      12:00:25.052 : Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
      12:00:25.052 : Heater 1 is on, I-accum =WiFi: xmit: 0
      12:00:25.052 : 0.0
      12:00:25.052 : === GCodes ===
      12:00:25.052 : Segments left: 0
      12:00:25.052 : Stack records: 1 allocated, 0 in use
      12:00:25.052 : Movement lock held by null
      12:00:25.052 : http is idle in state(s) 0
      12:00:25.052 : telnet is idle in state(s) 0
      12:00:25.052 : file is idle in WiFi: recv: 0
      12:00:25.053 : WiFi: fw: 0
      12:00:25.053 : state(s) 0
      12:00:25.053 : serial is ready with "M122" in state(s) 0
      12:00:25.053 : aux is idle in state(s) 0
      12:00:25.053 : daemon is idle in state(s) 0
      12:00:25.053 : queue is idle in state(s) 0
      12:00:25.053 : autopause is idle in state(s) 0
      12:00:25.053 : Code queue is empty.
      12:00:25.053 : === Network ===
      12:00:25.053 : Slowest loop: 167.18ms; fastest: 0.08ms
      12:00:25.053 : Responder sWiFi: drop: 0
      12:00:25.054 : tates: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      12:00:25.054 : HTTP sessions: 0 of 8
      12:00:25.054 : - WiFi -
      12:00:25.054 : Network state is running
      12:00:25.054 : WiFi module is connected to access point
      12:00:25.054 : Failed messages: pending 0, notready 0, noresp 0
      12:00:25.054 : WiFi firmware version 1.21
      12:00:25.054 : WiFi MAC addressWiFi: chkerr: 0
      12:00:25.054 : 5c:cf:7f:2c:24:51
      12:00:25.054 : WiFi Vcc 3.36, reset reason TWiFi: lenerr: 0
      12:00:25.054 : urned on by main processor
      12:00:25.054 : WiFi flash size 4194304, free heap 16792
      12:00:25.054 : WiFi IP address 192.168.0.239
      12:00:25.054 : WiFi signal strength -53dBm, reconnections 0, sleep mode modem
      12:00:25.054 : Socket states: 0 0 0 0 0 0 0 0
      12:00:25.054 : === Expansion ===
      12:00:25.054 : WiFi: memerr: 0
      12:00:25.054 : WiFi: rterr: 0
      12:00:25.054 : WiFi: proterr: 0
      12:00:25.055 : WiFi: opterr: 0
      12:00:25.055 : WiFi: err: 0
      12:00:25.056 : WiFi: cachehit: 0
      12:00:25.056 : WiFi: xmit: 31
      12:00:25.056 : WiFi: recv: 218
      12:00:25.056 : WiFi: fw: 0
      12:00:25.057 : WiFi: drop: 102
      12:00:25.057 : WiFi: chkerr: 0
      12:00:25.057 : WiFi: lenerr: 0
      12:00:25.057 : WiFi: memerr: 0
      12:00:25.058 : WiFi: rterr: 0
      12:00:25.058 : WiFi: proterr: 102
      12:00:25.058 : WiFi: opterr: 0
      12:00:25.058 : WiFi: err: 0
      12:00:25.059 : WiFi: cachehit: 116
      12:00:25.059 : WiFi: xmit: 204
      12:00:25.059 : WiFi: recv: 1777
      12:00:25.060 : WiFi: fw: 0
      12:00:25.060 : WiFi: drop: 592
      12:00:25.060 : WiFi: chkerr: 0
      12:00:25.060 : WiFi: lenerr: 0
      12:00:25.060 : WiFi: memerr: 0
      12:00:25.061 : WiFi: rterr: 0
      12:00:25.061 : WiFi: proterr: 0
      12:00:25.061 : WiFi: opterr: 0
      12:00:25.061 : WiFi: err: 0
      12:00:25.062 : WiFi: cachehit: 0
      12:00:25.062 : WiFi: xmit: 65
      12:00:25.062 : WiFi: recv: 48
      12:00:25.063 : WiFi: drop: 0
      12:00:25.063 : WiFi: chkerr: 0
      12:00:25.063 : WiFi: lenerr: 0
      12:00:25.063 : WiFi: memerr: 0
      Gone as far as erasing the board, and reinstalling all firmware to no affect.
      Turned all debugging on but I don't seem to get any reaction from the Duet when trying to connect to the web interface. I just get the following error from the web interface:
      This site can’t be reached
      192.168.0.239 refused to connect.
      However if I specify port 80 I still get an error in the webpage, but this time the debugging picks up the attempted connection and gives:
      12:31:45.580 : New conn on socket 1 for local port 80
      12:31:45.580 : HTTP connection accepted
      12:31:45.580 : Found responder
      12:31:45.580 : Received 179 bytes
      12:31:45.581 : Sending reply, file = no
      12:31:45.581 : Webserver: rejecting message with: 500 unexpected newline
      No other port seems to prompt a response.
      If anyone can help I would appreciate it. If I have missed out any useful information please say.
        Unfortunately the M122 output is somewhat garbled. Please try connecting to the Duet USB port using a terminal emulator instead of whatever host program you are using, and run M122 again.
        Are you able to ping the Duet's IP address from the PC?
        What error message do you get in the browser when you open a new tab and enter the Duet's IP address into the address bar?
        • divvet
          divvet last edited by divvet
          Apologies, I am currently connected by USB but did notice the output from YAT was jumbled up. I got the output from Repetier because I thought it had outputted correctly, on closer inspection I can see what you mean.
          This is another problem, why am I receiving garbled output? I will try another USB cable now.
          To answer your other questions, I am able to ping the Duet's IP, and the message I get is:
          Your Duet rejected the HTTP request: page not found
          edit: spelling
          • divvet
            Just changed cable, as you can see YAT output is worse:
            serial: M122
            Static ram: 28476
            Dynamic ram: 96236 of which 0 recycled
            Exception stack ram used: 380
            Never used ram: 5980
            Tasks: NETWORK(ready,548) HEAT(blocked,1248) MAIN(running,3484)
            Owned mutexes:
            Last reset 01:39:51 ago, cause: reset button or watchdog
            Last software reset at 2018-08-14 23:21, rWiFi: pr<DEL>Conn 0: free
            eason: User, spinning module GCodes, availWiFi: Conn 1: free
            able RAM 5656 bytes (slot 1)
            Error status: 0
            Free file entries: 10
            SD card 0 detected, interfWiFi: Conn 2: free
            MCU temperature: min 38.8, current 39.2, max 39.4
            Driver 0: standstill, SG miWiFi: Conn 3: free
            WiFi: Conn 4: free
            n/max nWiFi: Conn 5: free
            ot available
            Slowest loop: 1.0WiFi: Conn 6: free
            9ms; fastest: 0.08ms
            Scheduled moves: 14, completed moves: 14
            ===WiFi: Conn 7: free
            WiFi:
             Heat ===
            Bed heateWiFi: xmit: 0
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            file is idle inWiFi: recv: 0
             state(s) 0
            === Network ===
            Slowest loop: 166.77ms; fastest: 0.08ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) TelWiFi: fw: 0
            net(0) Telnet(0)
            - WiFi -
            WiFi MAC addresWiFi: drop: 0
            s 5c:cf:7f:2c:24:51
            WiFi Vcc 3.36, reset reason Turned on by main processor
            WiFi flash sWiFi: chkerr: 0
            ize 4194304, free heap 16384
            WiFi signal strength -56dBm, reconnections 0, sleep mode modem
            === Expansion ===
            ok
            WiFi: lenerr: 0
            WiFi: memerr: 0
            WiFi: rterr: 0
            WiFi: proterr: 0
            WiFi: opterr: 0
            WiFi: err: 0
            WiFi: cachehit: 0
            WiFi:
            WiFi: xmit: 56
            WiFi: recv: 341
            WiFi: fw: 0
            WiFi: drop: 197
            WiFi: chkerr: 0
            WiFi: lenerr: 0
            WiFi: memerr: 0
            WiFi: rterr: 0
            WiFi: proterr: 197
            WiFi: opterr: 0
            WiFi: err: 0
            WiFi: cachehit: 355
            WiFi:
            WiFi: xmit: 527
            WiFi: recv: 3203
            WiFi: fw: 0
            WiFi: drop: 1123
            WiFi: chkerr: 0
            WiFi: lenerr: 0
            WiFi: memerr: 0
            WiFi: rterr: 0
            WiFi: proterr: 0
            WiFi: opterr: 0
            WiFi: err: 0
            WiFi: cachehit: 0
            WiFi:
            WiFi: xmit: 120
            WiFi: recv: 83
            WiFi: drop: 0
            WiFi: chkerr: 0
            WiFi: lenerr: 0
            WiFi: memerr: 0
              dc42 administrators @divvet last edited by dc42
              @divvet said in Duet Wifi interface suddenly stopped working:
              That means the web interface files were not found in the /www folder of the SD card. I suggest you move the SD card to a PC, rename or delete the old /www folder if it exists, create a new /www folder, and unzip the contents of DuetWebControl.zip into it. Then safely remove/eject the SD card, put it back in the Duet and start the Duet.
              The output from YAT is mostly OK, it's just the software reset data that is slightly garbled.
              • divvet
                I despair sometimes πŸ™‚ Don't know why but I just reset the board and now the web interface is working and my terminal output has gone back to normal. I have done this 100 times today, why this latest one was any different I don't know.
                Sorry to be a waste of time, don't have a clue what has happened πŸ™‚
                  For some reason the Duet was unable to read the file www/reprap.htm. This could mean that the SD card failed to mount - but then it wouldn't have executed config.g, so it wouldn't have processed the M552 S1 command to connect to your router.
                  I suggest you consider the possibility that your SD card may be on the way out, so back up all the files on it and have another SD card ready.
