    network problem
    Firmware installation
    641
    • gideon
      gideon last edited by
      Hi, I have a question about the network settings of the duet
      I have the
      Firmware Name: RepRapFirmware for Duet 2 WiFi / Ethernet
      Firmware Version: 2.01 (RTOS) (2018-07-26b2)
      WiFi Server Version: 1.21RC4 (08b3)
      I put this in config.g
      M550 PHevo gideon; Set machine name
      M551 P ******; Set password
      M552 S1 P192.168.0.35
      M553 P255.255.255.0
      M554 P192.168.0.1
      I have only ever put another ip in the beginning, via telnet or usb.
      now he does not want to use the ip 192.168.0.35 via the config.g
      what I overlook
      thank you in advance
        As explained at https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface the P parameter in the M552 command is for boards with an Ethernet interface only. On the Duet WiFi the IP address may need to depend on which network you connect to, so it is included in the m587 parameters.
        • gideon
          @dc42 said in network problem:
          @dc42 thank you for the explanation i'm going to try, would like to have a static ip address on the duet wifi,
          try to come out with the explanation from you
          • gideon
            I have now put this in config.g but my ip address remains at 192.168.0.50
            do I still forget something?
            M551 PgIdeonO4; Set password
            M552 S1; Enable network
            M587 S "gidbeneden" P "0118471596" I192.168.0.35 J192.168.0.1 K255.255.255.0; Configure access point and IP addresses. You can delete this line once connected
            M586 P0 S1; Enable HTTP
            M586 P1 S1; Enable FTP
            M586 P2 S1
            • fcwilt
              fcwilt last edited by
              When I need a device to have an unchanging IP address I use a "reservation" in the DHCP server.
              In many residential situations the DHCP server is part of the "router" which provides access to your Internet service and provides the WiFi network to your home.
              A reservation is simply of way of telling the DHCP server that when a certain device (identified by its hardware MAC address) "asks" for a IP address to always give that device a specific, unchanging address which you get to specify when you setup the reservation.
              Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
                Phaedrux Moderator @gideon last edited by
                @gideon said in network problem:
                I notice you're using the release candidate of the wifi server firmware. Might be a good idea to update to the full release.
                gideon 1 Reply Last reply Reply Quote 0
                  dc42 administrators @gideon last edited by
                  Your M587 line looks OK to me, however M587 doesn't work within config,g. Send that command manually or from a macro file after the printer has started instead.
                  • gideon
                    gideon @Phaedrux last edited by
                    @phaedrux that is not the WiFi server version, he did this with other versions as well
                    • gideon
                      gideon @dc42 last edited by
                      @dc42 Okay thanks then we're going to put it in a marco
