    Tool changer commands
    5.1k
    • RajaaKahelundefined
      RajaaKahel @zerspaner_gerd
      @zerspaner_gerd
      "Make sure that all axes are referenced before the tool command!
      Only then will the tool script be triggered!"
      You mean by "referenced" homed? if so, then yes they are homed.
      "Do you have a start.g file? With me the duet does not select a tool at the print start, so you have somewhere a tool command."
      No I don't have a start.g file in the Duet. And in my slicer only G28 is included in the Start Script. I don't find any tool command..
      "Does not T-1 work? There must be no M84, M18, M1 before."
      I tried T-1 and M1 in the Start Script of my slicer, they do nothing. After I upload a print to the Duet, it immediately choose T0 (but doesn't activate the tpost1.g (same if I manually send T-1 or M1 before I start a print).
      You can activate tools with T# P0 (# = Tool Number) without changing the tool
      Where should I put T# P0?
      Again, Duet is always activating T0 (even if the first tool to run is T1) when starting to heat up, but it does not activate the tpost1.g.
        RajaaKahel
        Here are all my settings if that helps..
        Macros:
        https://drive.google.com/open?id=1Nwte-EtKEzL_ogCqJp7PMQ2qsLK7RBkM
        Configurations:
        https://drive.google.com/open?id=1q-h8eojJ91CQwK2p5YhWKuQaQph0sQ_T
        0_1535131031908_8.gcode
          dc42 administrators @RajaaKahel
          @rajaakahel said in Tool changer commands:
          But the problem is when I start a print, Duet is always activating T0 (even if the first tool to run is T1) when starting to heat up, but it does not actually go and pick T0 tool (so it thinks T0 is already picked up).
          That probably means you have either a T0 command or a M109 command near the start of your GCode file before the printer has been homed. M109 or M109 T0 will select T0 implicitly if no tool is selected, and if the printer hasn't been homed than the tool change macros won't be run.
          RajaaKahelundefined 1 Reply Last reply Reply Quote 0
            RajaaKahel @dc42
            @dc42 said in Tool changer commands:
            M109
            This is my Start and Ending Scripts in Simplify3D, nothing else is there in between:
            Start Script:
            G1 E15 F3000
            G28 ; home all axes
            G1 Y37
            Ending Script
            G1 E-15 F4000
            M104 S0 ; turn off extruder
            M140 S0 ; turn off bed
            T0
            ;M98 P/macros/parkT0
            G28 X ; home x and y axes
            G28 Y ; home x and y axes
            M84 ; disable motors
            M107
            M1
            I can't find any M109. Where in the Duet I can look for what is causing this? You see I attached all the files in my last post, I can't either find anything in them, please check them yourself too. Maybe my firmware is bad somehow? especially that I have another problem that I have to fix in order for my printer to function! (G10 Z offset for T1 simply doesn't work) as you see here:
            https://forum.duet3d.com/topic/6517/setting-z-offset-for-t1/15
            Any suggestions please? (at least I have to fix the T1 Z offset issue).
            Firmware Version: 1.21 (2018-03-21)
            WiFi Server Version: 1.21RC4(08b3)
            Web Interface Version: 1.21-RC4
              Please post the first 50 or so lines (not counting comment lines) of the GCode file generated by your slicer. You may find that it has inserted a M109 command before your start GCode.
                RajaaKahel
                A file starts with T0:
                G90
                M82
                M106 S255
                M140 S0
                M104 S180 T0
                M104 S180 T1
                M109 S180 T0
                M109 S180 T1
                G1 E15 F3000
                G28 ; home all axes
                G1 Y37
                G92 E0
                G1 E-3.0000 F2400
                G1 Z0.600 F1800
                ; process Process1-1-1-1-1
                ; layer 1, Z = 0.200
                T0
                ; tool H0.200 W0.720
                ; inner perimeter
                G1 X194.300 Y161.800 F18000
                G1 Z0.200 F1800
                G1 E0.0000 F720
                G92 E0
                G1 X194.944 Y161.800 E0.0409 F1125
                G1 X194.821 Y162.257 E0.0709
                G1 X194.324 Y162.390 E0.1036
                G1 X194.300 Y162.404 E0.1053
                G1 X194.300 Y161.800 E0.1436
                A file starts with T1:
                G90
                M82
                M106 S255
                M140 S0
                M104 S180 T0
                M104 S180 T1
                M109 S180 T0
                M109 S180 T1
                G1 E15 F3000
                G28 ; home all axes
                G1 Y37
                G1 Z0.600 F1800
                ; process Process1
                T1
                ; tool H0.200 W0.480
                ; inner perimeter
                G1 X220.180 Y161.680 F18000
                G1 Z0.200 F1800
                G92 E0
                G1 X221.135 Y161.680 E0.0404 F1125
                G1 X221.085 Y161.759 E0.0443
                G1 X220.921 Y162.368 E0.0710
                G1 X220.405 Y162.482 E0.0934
                G1 X220.180 Y162.611 E0.1044
                G1 X220.180 Y161.680 E0.1438
                G1 X220.180 Y177.346 F18000
                True, there is M109 before G28! How can I fix this please although as you see nothing in my Start Script is there!
                Start Script:
                G1 E15 F3000
                G28 ; home all axes
                G1 Y37
                  In most slicers, if you put tool heating commands in your start GCode then the slicer won't generate them itself. So you use something like this in your start GCode:
                  G28 ; ensure homed before selecting tool
                  G10 P0 S[first_layer_temperature] ; set tool 0 temperature
                  T0 ; select tool
                  M116 ; wait for all temperatures - not needed if you already do it in your tpost files
                  The details will depend on your slicer.
                    RajaaKahel
                    Thank you for your time DC42. I'll try to fix this. Now I know it's because of the slicer.
                    zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
                    • zerspaner_gerdundefined
                      zerspaner_gerd @RajaaKahel
                      @rajaakahel
                      In S3D the variable is:
                      [extruder0_temperature]
                      G10 P0 S[extruder0_temperature]
                      Here is my S3D Start Code, maybe it will help you:
                      M104 S[extruder0_temperature] T0 ; heat left
                      M104 S[extruder1_temperature] T1 ; heat right
                      G28 ; home all axes
                      G1 X10 Y10 F9000 ; bring extruder to front
                      G92 E0 ; zero the extruded length
                      G1 Z40.0 F3000 ; lower
                      G29 S1
                      T1
                      G10 P1 S[extruder1_temperature] R[extruder3_temperature]
                      M98 P0:/sys/S3D_Priming.g
                      T0
                      G10 P0 S[extruder0_temperature] R[extruder2_temperature]
                      G1 X50 Y15 F6000 ; wipe
                      ; 1ster layer
                      I use extruder 3 and 2 as standby temperature
                      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                        zerspaner_gerd
                        For Singel print I use a different start code, so that only one tool is heated.
                          @zerspaner_gerd Thank you, i'll check that 🙂
                            RajaaKahel
                            Thank you all for the help. Now I can start a print with no tool is pre-selected and finish the print with all tools parked. The problem solved by un-checking the Wait For Temperature box! So now a print starts with both tools heat in standby mode.
                            And to make the tools reach the temperature before they start printing I put M116 in tpre0.g and tpre1.g (because I removed the M109 by un-checking the Wait For Temperature box in S3D).
