    Connecting a DA SSR
    1.1k
    • Nxt-1undefined
      Nxt-1
      I am in the process of wiring up an very high powered AC heated bed, using a SSR to control it. The printer originally came with the DC bed connected to the Duet's GND terminal and the 12V from the PSU. I am wondering whether I reuse this wiring to connect my SSR. Or is there a good reason to find a place in the delta towers to run an extra wire connecting Duet bed + and SSR + ?
      Below, a simple drawing of how I plan to wire it.
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • fcwiltundefined
        fcwilt
        If you wire it as shown the bed heater will always be on - I cannot imagine that is what you want.
        Check the normal bed heater connector on the Duet.
        One terminal is marked with a "-" symbol, the other with a "+" symbol.
        Connect those to the SSR control inputs, observing polarity.
        BTW what's a TCO?
        • Nxt-1undefined
          Nxt-1
          @fcwilt said in Connecting a DA SSR:
          Why would the heater be always powered? The bed output of the Duet still opens and closes the circuit I imagine.
          BTW what's a TCO?
          TCO stand for thermal cutout, basically a temperature triggered fuse.
          • sigxcpuundefined
            sigxcpu
            Mark you different GNDs to be more clear.
            Nxt-1undefined 1 Reply Last reply Reply Quote 0
            • Nxt-1undefined
              Nxt-1 @sigxcpu
              @sigxcpu As requested 🙂
                Yes, that will work.
                • Nxt-1undefined
                  Nxt-1 @dc42
                  @dc42 said in Connecting a DA SSR:
                  Is there any consequence or disadvantage wiring it this way?
                    dc42 administrators @Nxt-1
                    None that I can think of.
                    • fcwiltundefined
                      fcwilt @Nxt-1
                      @nxt-1 said in Connecting a DA SSR:
                      Because the way you had it drawn originally you had the - terminal of the SSR connected to a terminal on the Duet labeled GND. You had the + terminal of the SSR connected to +12, thus the SSR would be on as long as the power supply providing the +12 was on.
                      Now you have changed the diagram to show using the BED- terminal which is NOT ground. Connecting that way will work.
                      And as mentioned if it makes things simpler or clearer you can connect the BED+ terminal to the SSR + terminal.
