    esteps/mm values not being taken into account?
    • r123
      r123 last edited by r123
      I'm running on Duet Wifi
      Firmware Version: 2.01(RTOS) (2018-07-26b2)
      WiFi Server Version: 1.21
      Web Interface Version: 1.21.2-dc42
      Am trying to adjust the esteps/mm and editing the M92 E304: XXX line in config.g doesn't seem to make the blindest bit of difference to the amount extruded when run the 100mm test. (Tried values XXX = 304 up to 390 and always 95mm is extruded??)
      Has anything changed that means this line isn't taken into account?
      • r123
        r123 last edited by
        Actually, don't remember/understand what the colon ":" is for?
        what does this syntax mean with two E numbers?
        when setting steps/mm for X and Y axes we just put one number?
          The colon seperates values for multiple extruders. If you only have one extruder you only need one number.
          • deckingman
            deckingman @r123 last edited by
            @r123 That's because printers only have a single X and Y axis but often have multiple extruders (I have 5 on my mixing hot end). So the colon is used to set the steps per mm for each of the multiple extruders. If you only have a single extruder, you don't need the colon so taking it out might cute your problem.
            • r123
              r123 last edited by
              Thanks a lot guys, that did it. Just put in one number and now it's perfectly calibrated.
              Goodness knows how long I've had two numbers in the config file have copy pasted someone elses to get started. Miracle made it so far!
              Thanks again
              • wilriker
                wilriker Moderator last edited by wilriker
                For sake of completeness: the default values for steps/mm
                • X/Y: 87.489
                • Z: 4000
                • E: 420
                So I guess you have been running on 420 all the time.
                Manuel
                My Tool Collection
