    Duet embedded server stops responding after upload
    • Smartinez
      Smartinez last edited by
      Hi!
      I am having problems trying to automatize my Duet uploads.
      I use pycurl to upload to rr_upload. And it is being successful most of the times, but every now and then the same file makes our duets to stop responding with a URL ERROR [[Errno 111] Connection refused.
      The printers keeps printing, but we cannot longer communicate with it. I tried different firmware versions.
      I can ping the printer and it responds back.
      Anyone experienced this kind of problem before?
      Here is my current code to upload to the duet
          c = pycurl.Curl()
          upload_url = "http://%s/rr_upload?name=gcodes/%s&time=%s" % (self.config['ip'], onlyfiles[0], get_timestamp())
          file_name = join(self.print_folder, onlyfiles[0])
          c.setopt(c.HTTPHEADER, ["Content-type: application/json"])
          c.setopt(c.URL, upload_url)
          c.setopt(c.POST, 1)
          c.setopt(c.VERBOSE, False)
          file = open(file_name, "r")
          c.setopt(c.POSTFIELDS, file.read())
          c.perform()
          c.close()
          file.close()
      Is there any example of using python to upload into the Duets?
      Thanks!
        Hi, try sending a rr_disconnect http request after the file upload completes. That will free up the server resource. HTH David
