Can access but cannot control....
  • Hi,
    After 4 correct prints, today I connected the printer and I found the following problem:
    • The extruder has disappeared.
    • The bed does NOT detect the temperature
    • I've tried Homing, and the engines make noise but it DOES NOT move.
    • The WiFi, after restart, does NOT connect automatically, I have to restart it by DWC.
    • The same functionality that I have for the DWC, I have it for the DueFirmware Panel
    Panel Due Image
    It's a DUET 2 WiFi board
    The firmwares that it carries in these moments, are, if I remember correctly, those that it took when it installs it.
    Firmware Name: RepRapFirmware for Duet 2 WiFi / Ethernet
    Firmware Version: 1.21 (2018-03-21)
    WiFi Server Version: 1.21RC4 (08b3)
    Web Interface Version: 1.21-RC4**
  • i have try to uptadte firmwares.... but the same
    in this moments:
    Firmware Version: 2.0(RTOS) (2018-06-05b3)
    WiFi Server Version: 1.21RC4(08b3)
    Web Interface Version: 1.21.1
    Check that you have the correct files in /sys on the SD card, and check that the config.g file looks ok in particular.
  • @dc42
    again ... thanks DC42.
    it was a typographical error in config.g .... it had that instead of M558, it had M559 ...
    Solved, thanks
