E3D Lite6 Thermistor Configuration w/Duet Wifi
I'm hoping someone could verify (or amend) my info on the relevant M305 parameters for configuring the thermistor that comes with E3D's Lite6 HotEnd.
Hotend: E3D Lite6 (listing)
Thermistor: Semitec 104GT (listing, datasheet)
Resistance at 25 Deg (C): 100K
Beta: 4267K
Hence, my M305 in config.g currently looks like this:
M305 P1 T100000 B4267 R4700
Are these parameters right? Is there something I'm missing and need to add?
Also, I'm assuming the R parameter ('series resistor value') relates to the onboard resistor on the Duet Wifi? If so, is 4K7 the correct value?
Thanks!
SnowCrash
That's not right. see https://e3d-online.dozuki.com/Guide/Lite6+RepRap+Firmware+Configuration/30?lang=en.
@dc42 said in E3D Lite6 Thermistor Configuration w/Duet Wifi:
Thank you very much, @dc42!
Used the configurator and got this:
; Heaters M140 H-1 ; Disable heated bed M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S240 ; Set temperature limit for heater 1 to 240C
Makes more sense?
Yes. You might want to set the temperature limit a little higher to allow for overshoot when heating up.
Thanks for the suggestion, @dc42.
I considered setting the limit higher, however the Lite6 has a PTFE tube inside and E3D warns that the HotEnd shouldn't go above 240 deg or that tube can get damaged so I kept the limit to that.
