    Question about delta with bed leveling screws
    • fcwiltundefined
      fcwilt
      When you have a delta with bed leveling screws when should they be adjusted (if at all) and how?
      I would think prior to running auto-cal it would be good to have the bed as level as possible but not sure how to do that. I don't want to do something that will mess up the auto-cal procedure.
      Thanks.
        You could run 6-factor auto calibration, then adjust the screws to remove any tilt that it wants to correct for. Alternatively, use a carpenters square to adjust the bed to be perpendicular to the towers.
        • fcwiltundefined
          fcwilt @dc42
          @dc42 said in Question about delta with bed leveling screws:
          Thank you.
