Dead board??
Hi All,
want to see if there is anything I may be missing before I return my Duet Wifi......
was just starting a print when I lost web connection tried to reload nothing...
had a look at the duet no light on the WiFi so reset the board - no change
plugged it in to USB no device - oh oh!
notice whenever its powered from USB(that works at least) the WiFi module gets HOT
tried:
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respondno response to anything.
before I take it back to E3d on Monday is there anything else I can try or is it dead and if so bad luck or something I could have done wrong?
have red and green lights for V+ and 3.3V
and red light either side of USB nothing else plugged in but if I plug in the end stops the lights respond -
If the WiFi module is hot (not just warm, which is normal when it is connected) then there are two likely scenarios:
- The WiFi module only has developed a problem.
- There has been a short between VIN and either +5V or +3.3V, and multiple components on the Duet (including the WiFi module) have failed. In particular, check whether the main processor (the large square chip) and U11 are getting hot.
@dc42 I would go with hot. If I touch with the back of my hand then painfully hot not just warm. U11 is cold and the processor just warm.
Not sure if its related but I was getting frustrated with unreliable wifi at boot.
On average about 1 in 10 reboots either with a config change or with emergency stop would result in the wifi not starting. This was always resolved with a reset or restarting wifi from terminal but still frustrating. In retrospect could this have been the module showing it was not happy?
I didnt know if this was normal so wasnt really focused on it.
Thanks for the quick responce
In that case, if your Duet is still under warranty, please request a repair or replacement.
Yes only 2 weeks. Already spoken to E3D but wanted to ask on here to be sure it wasnt me missing something stupid.
Thanks again
