Error "Failed to delete file" at startup
  • I'm having this error at startup:
    I do have a macro of this name at 0:/macros/Load_and_Unload/Load_PLA.g, but is neither at the root path as in the error and neither I want to delete it. The error does not appear every boot and when it does, it's always this same file.
    Any ideias?
    P.S.: It seems to happen mostly when I just uploaded a bunch of files by FTP and rebooted. (I use a configurator that compiles all the files on my linux machine and replace all of them on the duet by ftp when I change a file -- take a look at https://github.com/token47/duetcfgen ).
    Thank you!
  • Moderator
    Are you sure the files being uploaded by ftp are being uploaded correctly? I've noticed files being empty when uploaded via FTP. Not sure if it's related...
    I have seen similar error messages when trying to delete a folder or file. But not at startup.
