    Can't upload G-code
    • mcole
      mcole last edited by
      I've just updated an old AnyCubic delta machine with a spare Duet board, and all was going fine for a few days, but this afternoon I can't upload any new files.
      Initially everything looks fine ...
      But then it comes up with an error.
      And the file is not uploaded. I've tried two different computers, with Firefox and Chrome. Same error every time. I've also tried different files. There was at 10MiB file on there I removed to check the card had space, but it didn't make any difference.
      Firmware Version: 2.01(RTOS) (2018-07-26b2)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.3
      Web Interface by Christian Hammacher
      Licensed under the terms of the GPL v3
      Thank you for any help.
      SolidWorks user, crazy inventer and they pay me too!
        Can you copy and paste the results of an M122 diagnostics report?
          That indicates either an SD card write error, or that the size of the file size written wasn't correct.
          Perhaps you should try a different SD card?
          • mcole
            M122 output
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
            Board ID: 08DGM-9568A-F23SD-6J1F2-3SD6R-KVNMD
            Used output buffers: 3 of 20 (11 max)
            Static ram: 28476
            Dynamic ram: 96312 of which 16 recycled
            Exception stack ram used: 320
            Never used ram: 5948
            Tasks: NETWORK(ready,400) HEAT(blocked,1248) MAIN(running,3540)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:15:43 ago, cause: power up
            Last software reset at 2018-09-10 16:36, reason: User, spinning module GCodes, available RAM 5948 bytes (slot 1)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 22.1, current 33.5, max 34.3
            Supply voltage: min 12.2, current 12.3, max 12.5, under voltage events: 0, over voltage events: 0
            Date/time: 2018-09-11 09:42:02
            Slowest loop: 8.32ms; fastest: 0.07ms
            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
            Scheduled moves: 0, completed moves: 0
            Bed compensation in use: none
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 37.13ms; fastest: 0.01ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.21
              WiFi MAC address 2c:3a:e8:0b:27:ec
              WiFi Vcc 3.47, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 14304
              WiFi IP address 172.16.28.198
              WiFi signal strength -73dBm, reconnections 0, sleep mode modem
              === Expansion ===
            I'll try another card too
