Compiling the firmware for Duet Ethernet
I have a couple DuetWifi's (Duet 2) and have replaced one with a new Duet Ethernet (connected to a Duex5).
I have been modifying the firmware (Duet2.01 firmware) and want to know how to switch to compiling the firmware for Duet Ethernet.
Maybe I don't have to do anything ... will Duet2CombinedFirmware.bin file I used in the Duet Wifi work in the Duet Ethernet?
Yep, as long as you continue to use the Duet2_RTOS configuration, then Duet2CombinedFirmware.bin is still what you want.
Great thanks!
