    Printing speed is very very slowly ?????
    • ABDELRHMAN SAMIR ABOGABAL
      ABDELRHMAN SAMIR ABOGABAL last edited by
      the speed of printing is very very slowly
      this is my config.g
      ; Configuration file for Duet 0.8.5 (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Dec 24 2016 09:54:13 GMT-0800 (Pacific Standard Time)
      General preferences
      M111 S0 ;
      Debugging off
      G21 ;
      Work in millimetres
      G90 ;
      Send absolute coordinates…
      M83 ;
      ...but relative extruder moves
      M555 P2 ;
      Set firmware compatibility to look like RepRapFirmare
      M208 X0 Y0 Z0 S1 ;
      Set axis minima
      M208 X190 Y190 Z190 S0 ; Set axis maxima
      Endstops
      M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
      M558 P1 X0 Y0 Z1 F120 T6000 l1 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ;
      Drives
      M569 P1 S1 ;
      Drive 1 goes forwards
      M569 P2 S1 ;
      Drive 2 goes forwards
      M569 P3 S1 ;
      Drive 3 goes forwards
      M92 X80 Y80 Z800 E86 ; Set steps per mm
      M566 X15 Y15 Z0.2 E2 ; Set maximum instantaneous speed changes (mm/min)
      M203 X100 Y100 Z30 E20 ; Set maximum speeds (mm/min)
      M201 X1500 Y1500 Z500 E250 ; Set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E1500 ; Set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      Heaters
      M143 S260 ; Set maximum heater temperature to 260C
      M301 H0 S0.17 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M301 H1 S0.17 ; Set heater 1 output scale factor to 20%
      Tools
      M563 P0 D0 H1 ;
      Define tool 0
      G10 P0 X0 Y0 ;
      Set tool 0 axis offsets
      M550 Pshisan 3d printer ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M106 P0 S0.3 I1 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I1 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      • iDevelo
        iDevelo last edited by
        Maybe it's this:
        100mm per minute.
