crality cr-x
Good afternoon to all the first of all use translator I ask for forgiveness for my ignorance of English.
My business is that I have 2 tenado tornado co duet printing perfectly.
But I need help to configure another duetwifi for creality cr-x double extrusion, I am not able to configure it.
Please help -
Hello Jedr, welcome to the forum
Can you please explain the problem more? Please also upload the config files which you are using now, and what specific problems you are having. Nobody here can help until you explain more details.
; generated by RepRapFirmware Configuration Tool on Tue Sep 25 2018 10:15:27 GMT+0200 (Hora de verano romance); General preferences
M83 ; ...but relative extruder moves; Network
M550 PCREALITY CR-X DUET ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P4 S1 ; Drive 4 goes forwards
M350 X256 Y256 Z256 I0 ; Configure microstepping without interpolation
M350 E16:16 I1 ; Configure microstepping with interpolation
M92 X1280 Y1280 Z6400 E415:415 ; Set steps per mm
M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
M203 X9000 Y9000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
M201 X575 Y575 Z100 E575:575 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set active high endstops; Z-Probe
M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4725 C7.060000e-8 R4700 X1 ; Set thermistor + ADC parameters for heater 2 and remap it to channel 1
M143 H2 S280 ; Set temperature limit for heater 2 to 280C; Fans
M106 P0 S1 I0 F500 H0:2 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H0:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 ; Define tool 0
M563 P1 D1 H1 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
@jedr said in crality cr-x:
M92 X1280 Y1280 Z6400 E415:415 ; Set steps per mmI suggest using 16 microsteps interpolated to 256 to start with and calculate your steps per mm to suit that. Afterwards when everything is working you can experiment with different microstepping settings.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
This document should help get you started on commisioning your printer.
