    Connecting a CPP blower to Fan0
    cooling fan0 cpp blower
    • Zatsitundefined
      Zatsit
      Hello, everyone!
      I have recovered the blower fan from a CPP machine, and I use it as a remote fan for cooling printed objects. It is a compact, silent and very powerful unit, which, combined with an efficient diffuser, is capable of terrorizing any filament, as soon as it leaves the nozzle.
      The motor is a three-wire brushless, which I connected to a brushless driver module from ebay. This module is controlled by a variable voltage from 0 to 5V. For the moment, I use a potentiometer.
      My question is: how to order this module from pin Fan0, which provides controlled grounding in PWM?
      I have mounted a passive integrator, using a 47µF capacitor and a 2.2kOhms resistance, but I only get an on/off control, and inverted (0 = Full motor, any PWM value = motor off). But full motor, it's scary!
      How do I build the interface circuit? Thank you!
      Creator of Zatsit, the delta printer with none assembly
        I presume you have connected the input of your integrator to the FAN- pin of the FAN0 connector. Did you also connect a pullup resistor between FAN- and +5V?
