JavaScript Error after Probing - Duet Wifi
  • Hi everyone,
    I'm using BLTouch and trying to use 4-Point Bed Leveling, instead of Mesh Leveling on a cartesian printer.
    When I start the leveling, it probes all 4 points then i get an error messages, which disconnects the Web UI from the Duet Wifi. (screenshot below)
    Could anyone help me what could be the issue?
    Thanks!
  • Moderator
    What firmware versions?
    How is your BlTouch wired?
    Is it a genuine bltouch or a clone? What version?
    Does it work to home Z?
    Can you post your config?
  • Hey Phaedrux,
    Thanks for your reply.
    I believe I've found the issue.
    M667 S0 was missing in config.
    I've added it back and it's working with no issue right now.
    Good day!
    @biradam said in JavaScript Error after Probing - Duet Wifi:
    Hey Phaedrux,
    Good day!
    That's odd, because M667 S0 is the default. Perhaps you have a M665 line earlier in config.g that should be removed?
