[Solved] e3d heatsink fan turns off during heat up
  • Hello everyone,
    I have migrated my Anycubic i3 Mega to the duet wifi board over the weekend and I must say I'm very impressed with the quality of the hardware and the firmware. It's worlds better than the original board.
    I have noticed that e3d heat sink cooling fan turns off while the nozzle heats up. Once the nozzle reaches the desired temperature, the fan starts spinning again but it has a "hum" to it. The fan is connected to the pwm fan1 output.
    I have tried plugging it to an always on fan socket but it does the same thing, except the humming.
    The fan is 40mm 12V pwm computer fan (3 wires) but I only use 2 wires.
    I would like to have the fan on whenever the hot end exceeds 45C but have no clue how to do it and could not find the answer here. I am using firmware v2.02 RC2 and here is the fan config section
    M106 P0 S0 I0 F50 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F50 B1 L1 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1 T45                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1                                      ; Define tool 0
    G10 P0 X0 Y0 Z0 U0                                 ; Set tool 0 axis offsets
    G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
    Any help is greatly appreciated.
    Cheers!
  • Are you sure that the fan is PWM? PWM fan should have 4 wires.
  • You are right. It's not a PWM fan. It's just a normal 3-wire computer fan.
  • You have connected 2 wires and third is unconnected? Fan voltage? Jumper setting for FAN_VIN?
  • @briskspirit Yes. The fan is a 12V fan. I connected fan VIN (the red wire) to FAN1 V_FAN and fan ground wire to FAN1- . There is no jumper on FAN_VIN.
    Hmm... This jumper selects the input voltage according to the schematic. It's not quite clear to me why my fans work, even though I have no jumper at all.
    I will test it out this evening. I think you might have fixed the problem.
    Thanks for your help.
    It sounds to me that your fan is wired incorrectly. Does the machine use a common +12V or +24V wire to both the hot end heater and the heatsink cooling fan? If so then swapping over the 2 wires that connect to the E0 Heater terminal block on the Duet should fix it.
  • @dc42 I unplugged all the fans and motors and I did some testing after connecting the fan VIN jumper and confirmed 12V on the fan pins.
    • Tested the heaters => all OK
    • Connected one fan via the anycubic harness and undervoltage/temperature exceeded errors started popping up for all the drivers. This behavior was absent when the fan VIN jumper was absent. There was something which was shorting VIN to GND. I could hear the power supply clicking as it was protecting from a short.
    • Connected a fan directly to the fan pins (no harness) and things were working as expected
    I think that you are correct because Anycubic uses a wire harness and a PCB to distribute V+ (which arrives though multiple parallel, thin wires) among the fans and the heater block. The GND path is individual for each fan.
    So, yes, I think reversing the heater wires would have worked too but of course that's not what I did because I just saw your message 🙂
    In order to fix the issue, I added an additional wire directly from one of the 12V fan pins all the way to the two fans.
    Am I correct to assume that the 12V fan pin can handle the current from both fans simultaneously?
    @llamazen said in [Solved] e3d heatsink fan turns off during heat up:
    Yes. The fan outputs can handle up to at least 2A, although if you go above 1A then you should replace the 1A blade fuse by a 2A or 3A one. 12V brushless DC fans used in 3D printer typically draw no more than 250mA.
  • @dc42 Cool thanks!
