    Psu 5vsb and remote on help
    • da98520
      da98520 last edited by
      I have a meanwell epp-400-24 (https://www.trcelectronics.com/View/Mean-Well/EPP-400-24.shtml) and am not sure if I can use the remote on/off using the psu built in 5vsb 1amp max. I intend to also use the panel due 7i and either the piezo sensor or ir sensor. Anyone able to help confirm?
      Thanks
      DA
      • Built in 12V/0.5A auxiliary output (running a fan)
      • Standby 5V@1A with fan (0.6A without fan)
      • Built-in remote sense function
        Yes that should be possible. The Duet + PanelDue 7i draw less than 1A. The PS_ON facility may work in reverse.
