    Improved Desktop Chrome support and missing button?
    Duet Web Control wishlist
    • NoSkillzEngineerundefined
      NoSkillzEngineer
      Every time I try to edit a gcode or config file, or want to click on a gcode file to delete it, or edit a macro, and anything that involves like the "press and hold" or "right click" mouse button....I can never bring up these menus or pop ups when I need to on my desktop on Chrome.
      Every time I must resort to using my phone since I can press and hold to edit or delete stuff. So if I am testing a new gcode file, I have to upload it from my desktop but delete it from my phone which is just straight up annoying and eventually a bit aggravating.
      Does anyone else have this problem??
      Also, what happened to "half Z steps" in the options for UI general settings? Why'd that disappear? That was crazy helpful for me when trying to calibrate printers.
      Also maybe some better support for building and editing DWC so I could make my own theme? That would be nice.
        What version of Chrome are you using?
        What version of the DWC?
        I think maybe you should try reinstalling the DWC. Something doesn't seem right.
        You can specify the baby stepping height in the settings and you can specify the movement values for jogging by right clicking on the value in machine control.
        Also, themes were recently expanded to include many of the themes from https://bootswatch.com/ All the source files are in there, so I think you should be able to modify them if you know CSS, etc.
        https://github.com/chrishamm/DuetWebControl/
        • T3P3Tonyundefined
          T3P3Tony administrators @NoSkillzEngineer
          @noskillzengineer I just checked this on my desktop installation of chrome on Windows 10:
          right click works as expected.
          As I happened to have a VNC connection to a Raspi running chromium i thought i would check that, and it works as well:
          So possibly an issue with Chrome settings or DWC install (although if DWC is working in all other respects, and working on your phone then that does not sound like the issue).
          www.duet3d.com
          • Danalundefined
            Danal
            I don't really know how helpful "it works for me" posts are... nonetheless, here is another data point, from a "no issues" end user. In addition to below, I regularly use DWC on iOS Safari, and Chrome on a Mac laptop.
            Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
            Firmware Electronics:	Duet WiFi 1.02 or later
            Firmware Version:	2.02RC2(RTOS) (2018-09-07b2)
            WiFi Server Version:	1.21
            Web Interface Version:	1.22.3
            Google Chrome is up to date
            Version 69.0.3497.100 (Official Build) (64-bit)
            OS Name	Microsoft Windows 10 Pro
            Version	10.0.17134 Build 17134
            Other OS Description 	Not Available
            OS Manufacturer	Microsoft Corporation
            System Name	USDNLW11
            System Manufacturer	PowerSpec
            System Model	G460
            System Type	x64-based PC
            System SKU	592113
            Processor	Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core(s), 12 Logical Processor(s)
            BIOS Version/Date	American Megatrends Inc. L1.05P, 1/12/2018
            SMBIOS Version	3.0
            Embedded Controller Version	255.255
            BIOS Mode	UEFI
            BaseBoard Manufacturer	ASRock
            BaseBoard Model	Not Available
            BaseBoard Name	Base Board
            Platform Role	Desktop
            Secure Boot State	Off
            PCR7 Configuration	Elevation Required to View
            Windows Directory	C:\WINDOWS
            System Directory	C:\WINDOWS\system32
            Boot Device	\Device\HarddiskVolume1
            Locale	United States
            Hardware Abstraction Layer	Version = "10.0.17134.285"
            User Name	USDNLW11\Danal
            Time Zone	Central Daylight Time
            Installed Physical Memory (RAM)	16.0 GB
            Total Physical Memory	15.9 GB
            Available Physical Memory	11.3 GB
            Total Virtual Memory	18.3 GB
            Available Virtual Memory	11.8 GB
            Page File Space	2.38 GB
            Page File	C:\pagefile.sys
            Kernel DMA Protection	Off
            Virtualization-based security	Not enabled
            Device Encryption Support	Elevation Required to View
            Hyper-V - VM Monitor Mode Extensions	Yes
            Hyper-V - Second Level Address Translation Extensions	Yes
            Hyper-V - Virtualization Enabled in Firmware	Yes
            Hyper-V - Data Execution Protection	Yes
            • chrishammundefined
              chrishamm administrators
              AFAIR there were some options and/or add-ons that could block JavaScript right click events. I suggest you start your Chrome installation in safe mode once and check if that resolves your problem. If it does not, please try to restore your browser's factory defaults.
              Duet software engineer
