    Board cannot update firmware
    Firmware installation
    8
    23
    4.1k
    • GeckoBox3Dundefined
      GeckoBox3D
      @thooijer:
      Last night , experienced almost the same thing.
      Updated in the wrong order via the web interface.
      Could see a message that renaming failed in the web interface.
      Adding the new DuetWifiFirmware.bin to the sd card in the sys folder then M997 S0 would wipe the DuetWifiFirmware.bin file and
      gave the error :Firmware binary "DuetWiFiFirmware.bin" not found.
      Procedure 3 did the trick, updated to the latest firmwares and webinterface now.
      Exactly the same for me as well. Renaming files did not work at all, no matter what interface I used. Quite a pain though, I feel like there should be a warning message for installing non-compatible firmwares.
      • hum3undefined
        hum3
        Another in the heffalump trap!
        I had loaded the Web Interface first. Fix was like procedure 1.
        • Power down and extracted the uSD card
        • Copy and rename the latest set of files
        • Reinserted card and powered on
        • Send the command on the web interface M997 S0 this upgraded the firmware
        • Then upgraded the WIFI server using the web server
        Looking better - so back to rebuild the Ormerod 1. Such quiet motors - lovely.,
        • 3dprinting meatheadundefined
          3dprinting meathead
          @hum3:
          Nice, I guess i was the odd ball out, I updated the web controller and interface no problem but couldn't update the firmware-had to rename it, and now all set.
          Now I just need to figure out how to enable the configurator file I made. Commence the forum search!
          Edit:Nailed it! on to BLtouch
          If I can learn it, than anyone can learn it.
