Duet Wifi-Establishing Wifi connection requires multiple resets
The board has been replaced (incredibly fast) and is in operation.
Upgraded from the 1.03 to the current ver (1.04)Out of the box, cabled, with the restored files backed up from the original board
I started a terminal session (YAT)
M587 (List stored networks)
M588 "what ever net name was there" (M588 S"*" didn't work for some reason) (cleared existing stored networks)
M587 S"SSID" P"NetPass" (set my network wifi credentials)
M552 S1 (launched wifi, obtained IP adsdress)Found device IP and connect to DWC via Chrome
Shut power to board waited 10 count reapplied power
Same issue as the v1.03 board, no wifi (blue LED flash just after power up and ~1 count)
Pressed reset blue LED flash wait ~10 count
Pressed reset blue led flash, followed by 2 more then steadyI updated board as before, except all in one pass
Duet2CombinedFirmware.bin 2.02RC2(RTOS) (2018-09-07b2)
WiFi Server Version: 1.21RC4(08b3)
Web Interface Version: 1.21-RC4All seems to work as it should!!!
I restarted many times and it HAS NOT repeated the behavior.
I just finished a 2 hour print and restarted the board both from the power switch and the Emergency Stop button in DWC.
So far so good.
The wifi (LED) behavior is different compared to the last board
I am also getting different print results. i have to print more to know for sure, but a model that I've been having issues with actually printed the best it has since I changed to the DUET. It has some ringing that it didn't have before but overall it's printing better. No setting changes were made. (ringing might be machine related)
I'm glad it's working.
You are running old RC versions of DuetWiFiServer and Duet Web Control. I suggest you upgrade them to released versions.
My mistake, I copied and pasted the wrong information.
I should have copied it from the DWC not from the post above.I applied the same updates that were suggested on 10-10 by Phaedrux
This is what should be on the DUET
Firmware Version: 2.02RC2(RTOS) (2018-09-07b2)
Web Interface Version: 1.22.3I will confirm these values are what is on the DUET later this afternoon.
The DWC is definitely not the old version (easy visual thing) -
Thank you for your help and hard work.
