    I think i broke it
    1079
    • Monster Delta
      Monster Delta last edited by
      so yesterday i unplugged the z probe from the board while it was powered on and then the board wouldn't operate as normal so i powered off the machine and took the sd card out and put it in my pc to back it up but the sd card is not recognised in any device i have tried it in, so not much of a problem i have spares and i back up every week anyway but the board appears to have the firmware erased so i connected to the pc and opened device manager and sure enough it says bossa program port. now when i open the sam ba software and choose the port and board type and press connect it says could not connect and in the top of the box it says invalid chip id. I also tried bossa ad that just shuts down when i choose the port number. my question is have i broken it
      • chrishamm
        chrishamm administrators last edited by
        It sounds very much like you are using either a wrong or outdated bossa build. Try SAM-BA 2.17 instead: https://www.microchip.com/DevelopmentTools/ProductDetails/Atmel SAM-BA In-system Programmer
        Monster Delta 1 Reply Last reply Reply Quote 0
        • Monster Delta
          Monster Delta @chrishamm last edited by
          @chrishamm hi thanks for the response but i have tried all different versions of both bossa and sam ba
          • chrishamm
            Did you try updating the driver as well?
            • Monster Delta
              @chrishamm yes
              • Monster Delta
                I also tried bossac cmd line but it just says erase flash but doesn't do anything more
                • chrishamm
                  Well, sometimes USB3 ports don't work and can cause various problems. Try flashing it over a USB2 port if possible. If that fails, I suggest you try the same procedure again on another PC and/or attempt to boot from a Linux live CD like Ubuntu. See https://tutorials.ubuntu.com/tutorial/try-ubuntu-before-you-install#0
                  • Monster Delta
                    @chrishamm ok thanks I'll give that a try this evening
                    • Monster Delta
                      i just noticed that the main atmel chip is getting so hot it burns my finger to touch it
                        What type of Z probe is it, and how did you have it connected to the Duet?
                          dc42 administrators @dc42 last edited by
                          PS what is the PCB revision number of the Duet?
                          • Monster Delta
                            Monster Delta @dc42 last edited by
                            @dc42 hi its was the smart effector connected to the 4pin header on the duet board. The board is v1.01
                              It sounds to me that there has been a transient on the +3.3V rail which has damaged the processor (but not wrecked it completely) and the SD card. I guess that transient was caused when the Smart Effector was unplugged.
                              We may have some refurbished v1.01 boards available. If you are interested in buying one at a special price to replace your board, then please email info at duet3d dot com.
                              • Monster Delta
                                @dc42 thankyou i will definately send an email.
