    Y driver issue?
    • unknowdata
      unknowdata last edited by unknowdata
      Today, I notice that my CoreXY machine (Hypercube Evolution) makes rattle noise on Y motor and it refuses to move properly. It worked fine for past several months.
      Here are things that I tried
      • Swap X/Y motor wirings (I shut the printer down before doing it)
      • Use new cables
      • Test with spare motors on both X and Y drivers
      • Already make sure that connections are stiff
      • Connection on all motors are 100% correct
      • Tested with new motor outside the printer to make sure that belt tension isn't the case.
      • Tried to increase current to 1000mA (from 900mA). (X driver already works fine on 900mA).
      X driver could drives everything normally with all those changes with zero issue. Problem seems to persist on Y driver.
      There is no sign of burnt mark on Y driver and nearby SMD chips . They look just normal as others.
      To not ruins my printing schedule. I use this command to remap Y motor to E1 driver.
      M584 Y4 E3
      Now printer could move all axis normally. Printer is up and running again. But I have to ditch my second extruder plan in the future.
      Here are the questions.
      • Is my Y driver already blown up.
      • I bought this board since February this year. So I assume there is no more warrantee? I already blown one fan mosfet though...
      • Replacing/reflow driver locally seems impossible. I saw Duex2 0.8a is currently on sale. Is this a viable option if I buy this just for extra extruder? Should it be much more economical and way less downtime than asking someone to repair my board?
      • If above option is feasible. Since I'm using BLtouch to probe printer bed and some pin on 50-way connector are occupied. Where will all those pin goes if I choose Duex2 route. I checked the instruction here https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe but I'm too dumb to figure where and how. There is no wiring picture just like normal use case.
      Thank you
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC2(RTOS) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-95BNL-MGPSN-6J9DL-3S06Q-92WVW
      Used output buffers: 3 of 20 (14 max)
      Static ram: 28460
      Dynamic ram: 98064 of which 0 recycled
      Exception stack ram used: 492
      Never used ram: 4056
      Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3476)
      Owned mutexes:
      Last reset 00:33:40 ago, cause: power up
      Last software reset at 2018-10-12 11:59, reason: User, spinning module GCodes, available RAM 4220 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 8
      Free file entries: 8
      SD card longest block write time: 0.9ms, max retries 0
      MCU temperature: min 56.1, current 58.2, max 58.5
      Supply voltage: min 24.3, current 24.7, max 25.0, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max 0/195
      Driver 1: standstill, SG min/max 0/0
      Driver 2: ok, SG min/max not available
      Driver 3: standstill, SG min/max 0/50
      Driver 4: ok, SG min/max 0/186
      Date/time: 2018-10-12 12:36:52
      Slowest loop: 6.39ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 210, MinFreeDm: 136, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 9102, completed moves: 9090
      Bed compensation in use: mesh
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.4
      Segments left: 1
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X147.341 Y135.220 E3.38633" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 6.44ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      === Expansion ===
      Config file just in case
      0_1539324837217_config.g
        It does sound as though the driver has failed. You could use a DueX2 as you suggest, or have the driver and the fan mosfet replaced. Forum user W3DRK does Duet repairs in the US and I do them in the UK.
        • unknowdata
          Sweet! I will buy that soon. Thanks for your help.
