    Duet sometimes really slow? - I2C error or?
    Other control boards
    13
    147
    18.3k
      dc42 administrators @kazolar
      @kazolar said in Duet sometimes really slow? - I2C error or?:
      I am almost positive at this point these issues have to do with end stop wires having interference on them from the stepper wiring. It doesn't appear to bother regular end stops, but does mess with the i2c end stops, to such an extent that it kills the entire i2c connection. Outside of isolating stepper wiring, is there anything else we can do?
      1. Use normally-closed endstop switches. Normally-open ones are susceptible to capacitively-coupled interference when they are not triggered. Normally-closed ones are instead susceptible to inductive interference, which is easier to control.
      2. Use twisted pair wires to connect each endstop to the DueX, which minimises pick-up of inductive interference.
      Why is this an issue for i2c end stops only?
      The Duet has additional filtering on the endstop inputs.
      • kazolarundefined
        kazolar
        @dc42 I use silicone wire for moving axis, so twisting them doesn't work particularly well, that's where I'm seeing issues. Stationary end stops, I can easily isolate and eliminate all interference. I have 2 moving gantries, I have 2 end stops on each, primary x gantry has both end stops connected to the duet, no issues on it, the 2nd gantry has end stops going to the duex5, that's where I've had issues, originally on the A axis, now on the W axis. I've isolated both runs in their own nylon shielding, and I'm hoping that solves the problem. At least it solved it for the mean time and I was able to home. I have been using normally closed end stops for some time. Even with the wire which got all wrapped up around the stepper wire, end stop was reacting, and m119 was reporting it properly, but clearly there was significant enough intereference on the line that with the new firmware it wouldn't home, trigger a full reboot, interestingly enough it homed fine in the previous version, so if you added an error condition, I must have hit it. Just wondering if there is some filtering we can add to the endstop input itself to mitigate the issue.
          You could try a 100 or 200 ohm resistor in series with the wire to the STP pin of the endstop connector, and a 10nF capacitor between the STP and GND pins.
          If I was certain that the problem was interference on the endstop wires, then we could add filtering to the next revision of the DueX. However, I'm fairly sure that some users have reported getting this i2C comms failure even with no endstops connected to the DueX.
          • kazolarundefined
            kazolar
            There appears to be 3 vectors, end stops, thermistors and fans. I have not had any issues with fans. May just be related to my fan choices. I have had to isolate every endstop going to the duex5, as well as every thermistor going to the duex5. Obviously big wire bundles which include stepper wires are an interference nightmare. I'll run through a calibration routine tonight, as I level out each tool to each other, previously that was a guaranteed way to trigger i2c timeout issues. I may add the caps and filters proactively even if I things are working fine.
            • DocTruckerundefined
              DocTrucker
              I had issues with interference and false trips on a Duet Ethernet with Duex5 when I used a common for the switches to save wiring two cores back to the board for each switch. Swapped back to two cores for each switch and the interference went.
              • deckingmanundefined
                deckingman @kazolar
                I am almost positive at this point these issues have to do with end stop wires having interference on them from the stepper wiring. ....................................
                That might be true in your case but for me, I didn't have any I2C issues from when I installed the board in December 2016 until July(ish) 2018. As far as I can recall, I didn't make any hardware or wiring changes at that time. Also, there are no other threads related to I2C errors which pre-date July 2018 and that date is coincidental with the introduction of RTOS 2.0 firmware.
                • kazolarundefined
                  kazolar
                  Yes, I didn't have these problems with the 1.x versions, there was an i2c rewrite in 2.0, I couldn't go back to a 2.0 version which predates the rewrite easily as I have some custom changes I need to apply and I need to compile the firmware myself. What appears to happen is the i2c rewrite brought those hardware issues to the surface, because i can't blame the code if replacing the end stop wire fixes a problem. Just because it homed fine before the code change, simply says to me that there was hardware (wiring issue) and the new code is just exposing it. I'd rather shake out the wiring bugs now than have them bite me during a 100 hour print.
                    deckingman @dc42
                    @dc42 said in Duet sometimes really slow? - I2C error or?:
                    Ian, you can test the status of the endstops on the DueX by creating additional axes and making them visible. If you create 3 axes then the third one will use the E2 endstop input on the Due X. When that axis is visible, the state of the E2 endstop will show up in the Machine Properties page of the old DWC, and in the M119 response.
                    Yes I thought about that but maybe you don't remember the problems I had when I tried it before - this thread https://forum.duet3d.com/topic/6677/corexyuvwa-3rd-gantry-homing-solved/. I could only get it to work with the introduction of 2.03 beta2 when you introduced mapping of end stops to axes which is not possible in this RC candidate.
                    I'll see if a can cobble together some sort of configuration that'll make the end stops visible but as I said before, I won't be able to run the exact same sequence that was proven to provoke the problem unless I can map those additional end stops to the XY axes.
                    Just out of curiosity, why was that facility withdrawn and can you confirm that it'll be available in 3.0?
                    Cheers
                      dc42 administrators @deckingman
                      @deckingman said in Duet sometimes really slow? - I2C error or?:
                      It messed up the M585 command, which is needed by CNC users, and there was no easy fix. Endstop inputs can be mapped in firmware 3.0, see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview.
                        deckingman @dc42
                        David,
                        I just ran "the sequence" as far as I am able (everything apart from homing the upper gantry with mapped endstops). After which I changed (lowered) the temperature threshold for one of the thermostatic fans connected to the Duex5, to force the fan to come on which it did. Then I toggled the E2 end stop whilst observing the status on the machine properties page and that all worked as normal. After which I ran M122 and noted the following:
                        I2C nak errors 0, send timeouts 1, receive timeouts 0, finishTimeouts 1, resets 0
                        Is that what you would expect to see?
                        Cheers
                          David,
                          Cheers
                          Thanks for testing. I was expecting to see 1 reset as well, because it evidently had one I2C transaction error that it recovered from. I will check the code that counts resets.
                          EDIT: I omitted to increment the reset count at the proper place. I will fix this in the next RC or final release..
                            deckingman @dc42
                            @dc42 Cool. Do you want to carry on testing?
                            • kazolarundefined
                              kazolar
                              It appears I triggered a condition, and it appears to recover.
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC2-YG2 running on Duet Ethernet 1.02 or later + DueX5
                              Board ID: 08DGM-9T6BU-FG3S0-7JTD4-3S06K-1A4ZD
                              Used output buffers: 3 of 24 (18 max)
                              Static ram: 25676
                              Dynamic ram: 96832 of which 0 recycled
                              Exception stack ram used: 396
                              Never used ram: 8168
                              Tasks: NETWORK(ready,648) HEAT(blocked,1232) DUEX(suspended,164) MAIN(running,1688) IDLE(ready,156)
                              Owned mutexes:
                              Last reset 00:32:18 ago, cause: power up
                              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8196 bytes (slot 0)
                              Error status: 8
                              Free file entries: 10
                              MCU temperature: min 26.6, current 26.7, max 27.7
                              Supply voltage: min 24.3, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, SG min/max 0/93
                              Driver 3: standstill, SG min/max 0/242
                              Driver 5: standstill, SG min/max not available
                              Driver 6: standstill, SG min/max 83/432
                              Driver 7: standstill, SG min/max 39/449
                              Driver 8: standstill, SG min/max 0/413
                              Driver 9: standstill, SG min/max 29/422
                              Date/time: 2019-05-18 16:08:09
                              Slowest loop: 30.12ms; fastest: 0.08ms
                              I2C nak errors 1, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
                              Hiccups: 0, FreeDm: 169, MinFreeDm: 163, MaxWait: 70775ms
                              Bed compensation in use: none
                              Bed probe heights: -0.004 0.002 -0.006 0.002 -0.044
                              === DDARing ===
                              Scheduled moves: 434, completed moves: 434, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                              Heater 0 is on, I-accum = 0.2
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is idle in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 6.51ms; fastest: 0.03ms
                              HTTP sessions: 1 of 8
                              Interface state 5, link 100Mbps full duplex
                              • kazolarundefined
                                kazolar
                                @dc42 it recovered, thought not right away -- I have similar commands for each tpostx1.g
                                ;M116 P1
                                G90
                                G1 S2 V611.7 F8000
                                G1 S2 V641.7 F8000
                                G1 S2 V611.7 F8000
                                G1 S2 V641.7 F8000
                                G1 S2 V611.7 F8000
                                G1 S2 V641.7 F8000
                                G1 S2 V611.7 F8000
                                G1 S2 V641.7 F8000
                                G1 S2 V611.7 F8000
                                M106 R2
                                it does a wipe of a the nozzle across a brush, and this operation appeared to start operating in slow motion -- that is, there was a delay between each movement of the wipe, then after the tool change completed, the rest was fine and even the nak error count reset to 0 after another 30 minutes of configuration.
                                • kazolarundefined
                                  kazolar
                                  @dc42 back to slow motion.
                                  M122
                                  Used output buffers: 1 of 24 (16 max)
                                  Static ram: 25676
                                  Exception stack ram used: 412
                                  Never used ram: 8152
                                  Tasks: NETWORK(ready,520) HEAT(blocked,1232) DUEX(suspended,164) MAIN(running,1688) IDLE(ready,156)
                                  Owned mutexes:
                                  Last reset 00:24:42 ago, cause: software
                                  Last software reset at 2019-05-19 11:57, reason: User, spinning module GCodes, available RAM 8152 bytes (slot 3)
                                  Error status: 8
                                  Free file entries: 9
                                  SD card longest block write time: 75.7ms, max retries 0
                                  MCU temperature: min 24.7, current 25.2, max 26.6
                                  Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 0: standstill, SG min/max 0/109
                                  Driver 3: standstill, SG min/max 0/225
                                  Driver 6: standstill, SG min/max 89/428
                                  Driver 7: standstill, SG min/max 9/440
                                  Driver 8: standstill, SG min/max 0/415
                                  Driver 9: standstill, SG min/max 12/433
                                  Date/time: 2019-05-19 12:22:03
                                  Cache data hit count 3661079197
                                  Slowest loop: 121.00ms; fastest: 0.08ms
                                  I2C nak errors 0, send timeouts 24138, receive timeouts 0, finishTimeouts 24138, resets 0
                                  Hiccups: 0, FreeDm: 169, MinFreeDm: 163, MaxWait: 315729ms
                                  Bed probe heights: -0.153 -0.198 0.104 0.111 0.058
                                  === DDARing ===
                                  Scheduled moves: 359, completed moves: 359, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                  Heater 0 is on, I-accum = 0.4
                                  Heater 1 is on, I-accum = 0.0
                                  Segments left: 0
                                  Stack records: 2 allocated, 1 in use
                                  Movement lock held by aux
                                  aux is idle in state(s) 42 0
                                  === Network ===
                                  Slowest loop: 124.37ms; fastest: 0.02ms
                                  HTTP sessions: 2 of 8
                                  • kazolarundefined
                                    kazolar
                                    Stopped being able to sense duex5 end stops entirely, removed the extra resistors, back to testing again.
                                      I presume the -YG2 means you are using your own build of RRF. Are you certain that you have taken all of the 2.03RC2 changes into your build, in particular the changes to the CoreNG project?
                                      • kazolarundefined
                                        kazolar
                                        Positive. It wouldn't compile otherwise. For whatever it's worth. Been running fine since I removed the resistors.
                                          deckingman
                                          Thanks to @wilriker, I now have a version of firmware that incorporates the I2C changes but also restores end stop mapping so that I can use the exact same sequence of events that were proven to consistently provoke the errors. I tried it earlier today with no issues but that was not from an overnight shutdown. I'll try it again first thing tomorrow morning.
                                            deckingman
                                            @dc42 David,
                                            For info, I ran "the sequence" again today after an over night shutdown, with @wilriker 's firmware 2.03RC3-M574C (2019-05-28b1) (based on your firmware but with end stop mapping enabled). No problems encountered with movement, no I2C errors reported, and no I2C resets.
                                            Looking good so far........
