    CoreXY Hevo Sensorless homing problem with Y.
    • Maciek
      Maciek last edited by
      Hello.
      All previous topics are closed thats why I make new one.
      Sometimes Y axis is not homing properly. After X homing, it moves a bit and finish homing in wrong posiotion.
      It happens when print finish and carriage go to parking position. After that, when I upload file to print homing Y axis will be like I said.
      If before print Ill manually use homeall scrips it will go OK.
      Here is my homeall.g
      0_1539634869422_homeall.g
      M400 ; make sure everything has stopped before we make changes
      M913 X40 Y40 ; XY motors to 65% current
      M915 H400 X Y S2 R0 F0 ; set X and Y to sensitivity 3, do nothing when stall, unfiltered
      M574 X1 Y1 S3 ; set endstops to use motor stall
      G91 ; use relative positioning
      G1 S2 Z10 F1200 ; lift Z
      G1 S1 X-300 F3000 ; move right/back 325mm, stopping at the endstop
      G4 P500 ; wait 500msec
      G1 X5 ; move away from home
      ; lift Z
      ; X is homed at this point, now home the other axis
      G1 S1 Y-300 F3000 ; move beyond axis minimum
      G1 Y5 ; move away from home
      ;G1 Z5 F6000 S2 ; lift Z relative to current position
      G1 S1 Z-255 F1800 ; move Z down until the endstop is triggered
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      G1 Z-10 F1200 ; lower Z
      M913 X100 Y100 ; XY motors to 100% current
      G90 ; back to absolute positioning
      M574 X1 Y1 S1 ; define active low microswitches
      Sorry for the mess, Im new with Duet 🙂
      cheers
      • Maciek
        I did some tests. I made very fast printable gcode (about 1sec print) just to make printer start and stop. I repeated it over and over. About 10% of homings before print was failure - after X was homed, Y wasnt.
        I tried higher value of sensivity - with no luck.
        I tried higher homing speed - same.
        Same with motor current.
        Any idea?
        Here is my config.g:
        0_1539641962022_config_backup.g
        Here is newly edited homeall.g:
        M913 X40 Y40 ; XY motors to xx% current
        G1 S1 X-300 F6000 ; move right/back 325mm, stopping at the endstop
        G1 S1 Y-300 F6000 ; move beyond axis minimum
        G4 P500
          My best guess is that the motors are hotter at the end of the print, and this is increasing the stall sensitivity. So you could try the following:
          • Use a higher S number in the M915 command, to reduce the sensitivity;
          • Use a lower motor current during printing, so that the motors don't get as hot;
          • After printing, lift Z to move the nozzle away from the print, then reduce X and Y motor current (M913) or even turn them off completely, then pause for a while to let the motor windings cool a bit; then home the printer.
          I think stall-detect homing on CoreXY printers is more difficult than on other types due to the increased length (hence elasticity) of the belt, which makes it more difficult to get a hard stall.
          • Maciek
            Big thanks for reply David.
            I tried higher S in the M915 to reduce sensivity. '4' is limit for my ears. And even with that sometimes homing fails.
            Temperature in my opinion is not the issue. Both motors have same temperature and only Yaxis fails.
            Moreover, I tested it on cold motors. My test print gcode is so short that motors cannot get even warm.
            Im printing quite fast (100-150mm/s, 400mm/s travel, 5k acc), so current reduction is someting im afraid of.
            I start to think its something maybe with slicer start and end gcode.
            Starting:
            G28;
            G1 Z10;
            Ending:
            G4 ; wait
            M221 S100
            M104 S0 ; turn off temperature
            M140 S0 ; turn off heatbed
            M107 ; turn off fan
            {if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+20, max_print_height)}{endif} ; Move print head up
            G1 X0 Y200; home X axis
            M84 ; disable motors
            For now I just edited ending gcode to go to home position after print. It works, but its not how it should be.
              Phaedrux Moderator @Maciek last edited by
              @maciek said in CoreXY Hevo Sensorless homing problem with Y.:
              You wouldn't have to reduce it during the print, just for the homing moves. It could then be increased again.
                The G4 command in your end GCode should have a parameter to tell it how long to wait. Or you can use M400 instead to just wait for everything to stop moving.
