    two Y motors with separate endstops
    • norbu
      norbu last edited by
      Hi
      I have a printer with two motors on the y axis each of them has a endstop. One of this motors and endstops connected to the duex5 E2. I have mapped the motors together in the config.
      When i homing the Y axis both motors beginn working correctly but only this on how is connected to the duet board directly is stoping when the endstop is hitted.
      config.g
      ; Configuration file for testing Duet Ethernet and Wifi with V1.19 firmware
      FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
      ; Communication and general
      M111 S0 ; Debug off
      M550 PDuetTest ; Machine name and Netbios name (can be anything you like)
      M551 Preprap ; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
      ;*** Networking
      M552 S1 ; Turn network on
      ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
      M552 P192.168.88.100 ; (0 = DHCP)
      M554 P192.168.88.1 ; Gateway
      M553 P255.255.255.0 ; Netmask
      M555 P2 ; Set output to look like Marlin
      G21 ; Work in millimetres
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P4 S1 ; Drive 4 goes forwards
      M569 P5 S1 ; Drive 5 goes forwards
      M584 X0 Y1:5 Z2 E3:4 U5 P5
      M350 X256 Y256:256 U256 Z256 I0 ; Configure microstepping without interpolation
      M350 E16:16 I1 ; Configure microstepping with interpolation
      M92 X10666.667 Y10666.667:10666.667 U10666.667 Z10666.667 E420:420 ; Set steps per mm
      M566 X900 Y900:900 U900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X7200 Y7200:7200 U7200 Z180 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500:500 U500 Z500 E250:250 ; Set accelerations (mm/s^2)
      M906 X2000 Y2000:2000 U2000 Z2000 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 U0 Z0 S1 ; Set axis minima
      M208 X322 Y259 U259 Z556 S0 ; Set axis maxima
      M574 X1 Y1 U1 Z2 S0 ; Set active low endstops
      ;M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
      M557 X15:307 Y15:244 S20 ; Define mesh grid
      M140 H-1 ; Disable heated bed
      M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      homey.g
      ; homey.g
      ; called to home the Y axis
      ; generated by RepRapFirmware Configuration Tool on Tue Aug 07 2018 11:06:40 GMT+0200 (Central European Summer Time)
      G91 ; relative positioning
      M584 Y1 U5
      G1 S1 Y-264 U-264 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000 ; go back a few mm
      G1 S1 Y-264 U-264 F360 ; move slowly to Y axis endstop once more (second pass)
      G1 Z-5 F6000 S2 ; lower Z again
      M584 Y1:5
      G90 ; absolute positioning
      Thank you for any help
        The U endstop should be connected to the E0 endstop connector. Is that where you have connected it?
