Firmware 2.02 Release candidate 3 now available
Fyi
I just installed a previous version of the firmware and the baby steps are working. -
@dc42 I just done that and it’s not reading it, it shows the dame value as F, but even then it moves at 1.7mm/s.
M558
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 100mm/min, travel speed 100mm/min, recovery time 0.00 sec, heaters normal, max taps 10, max diff 0.01� -
About the strange notice that a motor not seems to be connected properly... As I did some tests yesterday, the message only popped up during the G32 command...? Maybe this could be a hint to find a possible problem / solution?
@3doeste said in Firmware 2.02 Release candidate 3 now available:
M558
Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 100mm/min, travel speed 100mm/min, recovery time 0.00 sec, heaters normal, max taps 10, max diff 0.01�1.7mm/sec is about 100mm/min, so that explains it. The question is, why does it have the travel speed set to 100 instead of 2000. Do you have any M558 commands in any other files, for example homing files? If you reboot the Duet and run M558 before you home the printer or run any other commands, does it report 100 or 2000 ?
@kuhnikuehnast said in Firmware 2.02 Release candidate 3 now available:
Did you get this message when running 2.02RC3, or only with 2.02RC2 ? You don't appear to have mentioned it before in this thread.
@dc42 said in Firmware 2.02 Release candidate 3 now available:
oh, sorry. I got on RC2 as a "red window- alert". On RC3 I now get a "yellow window" that disappears after a few seconds:
Warning: motor phase A may be disconnected reported by driver(s) 0 Warning: motor phase B may be disconnected reported by driver(s) 0 But the print and anything else works fine...?
Thanks.
- Is this on a Duet WiFi, Ethernet, or Maestro?
- Are you able to identify which command in your bed.g file provokes it?
- Is driver 0 driving the X motor as usual, or have you used M584 to re-map another axis or extruder to driver 0?
- What current do you have that motor set to?
Thanks.
It is a Duet Wifi (1.03), it is the X motor, current is set to 800 (same motor as on y). I just tried to figure out what exactly is causing the message but it is really strange! It only pops up sometimes. But if, then it almost always pops up if I start a print. Then after the G32 command and somewhere around the G29. If I don't print, I can move all axis, home all axis etc... (I can even execute my S3D- start-script...?)
As slicer I use S3D, here is the start-script:G21 ; metric values G90 ; absolute positioning M82 ; set extruder to absolute mode G28 ; home axis G32 ; auto bed compensation ; G28 Z ; home z M98 PClean_Nozzle.g ; G29 ; mesh bed levelling M98 PClean_Nozzle.g ; G92 E0 ; zero the extruded length G1 X20.0 Y20.0 Z0.2 F7800 ; start point for starting line G1 X140.0 Y20.0 E10 F800 ; extrude 8mm filament along 110mm movement in x G1 X150.0 Y20.0 Z0 F7800 ; separation move Z0 to keep up nozzle preasure G92 E0 ; zero the extruded length again and here the Clean_Nozzle.g file:
; go to start point G0 X225 Y68 Z10 F9000 ; Z not yet to prevent crash M564 S0 ; allow negative Z-value G0 Z4.5 ; start point reached G91 ; relative positioning ; start X0 Y0 front left G0 X15 Y13 F6000 ; 1. move G0 X-15 Y14 F6000 ; 2. move G0 X15 Y13 F6000 ; 3. move G0 X-15 Y0 F7000 ; end back left M564 S1 ; denie negative Z G1 Z5 ; lift Z at the end G90 ; absolute positioning -
Perhaps it's the nozzle cleaning script? Can you try running it a few times?
You can ignore the message, because the firmware doesn't do anything apart form warn you when the drivers report open circuit motors - but obviously it's annoying.
@k3lag uncheck "always show info area and main menu" option in user interface in DWC.
@paulowisk said in Firmware 2.02 Release candidate 3 now available:
Problem was stray '.' at end of the URL for my printer. I finally found the stray '.', it was in bookmark for the printer. Not sure how it got there but problem solved.
@dc42 Hi, it turns out I had an M558 on both my homeall and homez. I simply add the correct values at the end of the macro and problem solved.
One thing I noticed by accident is that the bed levelling, after homing all axes, crush in Y. Since I never used it, the coordinates are wrong, but anyway is it normal to go beyond the limits established?
The firmware intentionally allows you to use G30 commands that probe beyond the normal bed limits, because there are situations in which this is desirable.
I had another freeze with M600 last night. Same filament-change.g file as posted earlier, same symptoms. I don't know if the problem is something in my .g file or if M600 (which is new in this RC) has an issue. So far, M600 has worked 0 of 2 attempts. I've quoted my previous message on the issue below:
@garyd9 said in Firmware 2.02 Release candidate 3 now available:
Are there any restrictions on the commands usable in M600 macro? (filament-change.g ) I tried it tonight and when it hit the M600 macro, everything froze. The macro contained the following commands:
M83
G1 E-4 F2500
G91
G1 Z20 F5000
G90
G1 X0 Y85 F5000
M291 P"Change Filament"
M300 P5000None of the moves in the filament-change.g were run as far as I could tell. It appeared to just freeze when it hit the M600. The paneldue and DWC showed a paused state, but the movement buttons and resume buttons (on both UI's) didn't do anything. The only thing I was able to do was "emergency stop" (which did work.)
I confirm that there is a problem with M600 in the 2.02RC firmware. I will fix it in 2.02RC4.
M116 now accepts an optional S parameter to specify the acceptable temperature difference
Thank you for the implementation!
Is working! -
I just set up my new Maestro
Firmware Name: RepRapFirmware for Duet 2 Maestro
Firmware Electronics: Duet Maestro 1.0
Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
Web Interface Version: 1.22.4-b1Everything works nicely except the 12864 LCD.
I need to press reset on the Display for it to display something. On initial boot it shows nothing.
But the display text is garbled:This is my menu.
text R1 C1 F0 T"CoreXY"
text R15 C1 F0 T"Bed temp "
value N180 W30
text T" actual "
value N80 W30
text R30 C1 F0 T"E temp "
value N200 W30
text T" actual "
value N100 W30
also i just noticed the firmware configurator does not produce the M350 line for maestro.
Most 12864 displays reset automatically when they are powered up, but it looks like your display doesn't, or takes too long. You could try having just a single button on the mein menu, that loads the real menu you want, then press the encoder to get that menu.
For 2.02RC4 I will look at making the M918 command reset the display, if it doesn't already. That would give you the opportunity to use a G4 delay command in config.g before the M918 command, to give your display extra time to be ready.
Now that 12864 support is in the firmware does that mean it will work on a Duet WIFI/Ethernet?
