    Mini differential IR height sensor led not working
    IR Height Sensor
    • ricard0g0mes
      ricard0g0mes last edited by
      i have this attached to my jgaurora A5 and the led now does not work, but the sensor work's ok.
      Can someone tell me if i can do anything? The led is smd, very very small... i am not able to replace it...
        If you purchased the sensor within the last 6 months, and the board hasn't been damaged physically, ask your supplier to replace it under warranty. Otherwise, is there a makerspace or similar in your area, where someone else may be able to help you replace it?
        I can replace the LED, but unless you are in the UK then the costs of postage to and from me may make it un-ecomonic.
