gcode wiki docs needed
The G30 command has some additional "S" parameters that aren't documented on the duet3d gcode wiki (https://duet3d.dozuki.com/Wiki/Gcode)
I believe the newer S values are 8 and 9, but I'm really not sure what they do (and I'm having a hard time finding a definitive answer.) I think they are the same as 6 and 7 (??) but add the magic of figuring out any build plate tilt (A/B of M666.) I don't know if there are any prerequisites for this to work or not.
Can someone who can give a definitive answer please either update the wiki page or reply here and I can submit an update.
Thanks
Gary -
S8 and S9 apply to delta printer calibration. S8 = as S6 plus bed tilt correction; S9 = as S7 + bed tilt correction.
Thank you. I've updated the documents "Configuring RepRapFirmware for a Linear Delta printer" and "GCode" from https://duet3d.dozuki.com/c/RepRapFirmware. The document "Calibrating a delta printer" already included the information.
