PanelDue firmware 1.22 released
@brunofporto said in PanelDue firmware 1.22 released:
3- I run a macro for my Z-Probe tunning, that have some issues of not selecting the tool, but if called from PanelDue I do not get any warnings - it just locks as busy and do nothing (that is why I hit the Stop....)
When that happened, did the top of the PanelDue say "changing tool..."? (If so, I've had the same thing happen, but I have no idea why and I haven't been able to repeat on demand.)
@garyd9 said in PanelDue firmware 1.22 released:
For example, it's no longer possible to "baby step" twice in a row quickly via the paneldue. From the PanelDue "print" page, I tap "baby step" and I see the +0.02 and -0.02 buttons. As soon as I press one, I get a "Response" titled popup telling me that "Baby stepping offset is -0.02mm". I can't baby step again because that popup is "in the way." However, I can't tap the red X on the popup either (probably because the baby step popup is also up, behind the "response" popup.) The only escape is to wait a few seconds, or tap something like "Control" at the bottom - which will close BOTH the response popup and the baby step popup.
This was caused by a combination of 2 bugs. First, the baby stepping buttons were sending extra M290 commands that caused the existing baby stepping amount to be reported. Second, it wasn't possible to close a window if the close button was above or to the left of the previous window. These are both fixed in the forthcoming 1.22.1 release.
If I call M591 D0 it still not enough text room for the entire response.
Fixed in the forthcoming 1.22.1 release.
The stop button at the top left did not work like the equivalent at DWC and after pressing it PanelDue was not able to connect again until I hit the emergency stop at DWC
I'm sorry, I can't reproduce this. There is the problem that the STOP button on PanelDue doesn't always work instantly, because the command gets queued up; but other than that nit does the same as DWC i.e. resets the Duet after stopping it.
I'm closing this thread because I have just released PanelDueFirmware version 1.22.1 and I am about to create a thread about it.
