    Servo: PWM from Duet - Power from Buck Converter?
    • kuhnikuehnastundefined
      kuhnikuehnast
      Hi there,
      I already installed a BLTouch and used the GND / 5V- Pin of the Ribbon-Cable Mount. Now I would like to use some servos. As they also need 5V/GND, I don't want to do a "double - crimping". Is it possible to feed them with 5V / GND by a Buck converter?
      I did a quick sketch to illustrate my idea:
      greetings kuhni
        Yes you can do that.
