    After 1.21 lost fan slider even if it seems no temp controlled.
    Firmware installation
    • claustro
      claustro last edited by
      I am surely missing something but Iafter 1.12 update I uanble to see my fan slider connected to leds control.
      I can find only p1 configured as temp controlled fan , but web interface only show one slider ( pla cooling)
      Any idea?
      I have FAN1 for hot end FAN0 for pla cooling FAN 2 for leds. I need fan 2 silider
      Thank you
      Andrea
      My config
      M111 S0 ; Debug off
      M550 PDBOT ; Machine name (P + anything you like)
      M551 heather9 ; Machine password (used for FTP connections)
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address - If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M552 S1 ; Enable WiFi
      M555 P2 ; Set output to look like Marlin
      M564 H0
      ;M575 P1 B57600 S1 ; Comms parameters for PanelDue; Machine configuration
      M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S1 ; Drive 1 goes forwards. (Change if motor goes wrong way. Or just turn the motor connection 180 degrees around..)
      M569 P4 S1 ; Drive 4 goes forwards
      M574 X1 Y2 Z0 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0)
      M667 S1 ; set CoreXY mode
      ;M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation
      M92 X100 Y100 Z400 ; Set axis steps/mm. Check that the printer really move as much as you tell it. Not more and not less.
      M92 E422:422 ; Set extruder steps/mm. Change this to match your extruder.
      ;http://www.instructables.com/id/How-to-calibrate-the-Extruder-on-your-3d-Printer/?
      M906 X1000 Y1000 Z1300 E800 ; Set motor currents (mA). Increase if motor is to weak. Lower if motor gets too hot. 800-1000 is good for most.
      M201 X1500 Y1500 Z300 E4000 ; Accelerations (mm/s^2). The acceleration, speed and jerk is a setting you can alter to try making the printer to print as nice as possible..
      M203 X15000 Y15000 Z300 E1500 ; Maximum speeds (mm/min)
      M566 X600 Y600 Z24 E300 ; Maximum jerk speeds mm/minute
      M208 X300 Y300 Z300 ; set axis maxima (adjust to suit your machine)
      M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
      G21 ; Work in millimetres
      M83 ; ...but relative extruder moves; Z probe
      ;M558 P5 X0 Y0 Z1 H4 F450 T4000 ; Analog Z probe, also used for homing the Z axis
      ;G31 Z2.47 P500 S1 ; Set the probe height and threshold (put your own values here)
      ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
      ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
      ;M557 P0 X30 Y25 ; Four...
      ;M557 P1 X30 Y155 ; ...probe points...
      ;M557 P2 X250 Y125 ; ...for bed...
      ;M557 P3 X250 Y25 ; ...levelling
      ;M557 P4 X150 Y95 ; 5th probe point for levelling; Thermistors and heaters
      M557 X10:290 Y10:290 S70
      ;*** You can use S and B parameters to define the parameters of the thermistors you are using. Standard 100k thermistor from E3d is 4388 or 4725.
      M305 P0 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      ;M305 P2 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      ;***Choose if you want to use the M301 or the autotune results and M307 command. Don't use both.
      M301 H1 P10 I0.10 D100 T0.50 S1.0 ;PID settings for extruder 0 (no need for M301 if using M307)
      M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
      M570 S120 ;Increase to allow extra heating time if needed
      ;***Use for autotune. Comment out M301 if you do.
      ;M307 H0 A142 C293.5 D5.4 B0 ;Autotune result for bed
      ;M307 H1 A588.5 C242.9 D6.7 B0 ;Autotuen result for first nozzle; Fans
      M106 P1 T45 H1 ; enable thermostatic mode for fan 1 at temp 45 degrees. Fan turns on when P1(extruder 1) is above 45 degrees.; Tool definition
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      ;*** If you have a dual-nozzle build, un-comment the following 3 lines
      ;M563 P1 D1 H2 ; Define tool 1
      ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0 ; Axis compensation here
      M208 S1 Z-0.2 ; set minimum Z
      M501 ; Load Config-Override.g that is created using M500
      T0 ; select first hot end
      ;*** Fan config
      M106 P1 T45 H1
      ;*** BLTouch
      M307 H3 A-1 C-1 D-1
      M558 P5 X0 Y0 Z1 H5 F200 T5000
      M574 E0 S0
      G31 P100 X0 Y-20 Z0.50 P1
      ;*** Autupause
      M911 S12.0:19.5:22.0 // auto-pause at 19,5V, then either stop at 12V or auto-resume at 22V
      ;*** Filament sensor
      M591 D0 P3 S24.5 C3 R20 E3.0 ; Duet3d sensor for extruder drive 0 is connected to endstop input 3 (E0), 23.5mm/rev, 50% error detection tolerance, 3mm comparison length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      ;D = extruder drive number
      😜 = filament sensor type. P3 = Duet3D filament monitor without additional filament presence detection switch, P4 = Duet3D filament monitor with switch.
      ;Snnn = mm of filament fed per complete rotation of the sensor wheel. May be positive or negative.
      ;C = endstop number (0 = X, 1 = Y, 2 = Z, 3 = E0 etc.). Endstop inputs 5-9 which are on the DueX2 or DueX5 expansion boards cannot be used. Endstop inputs 10-11 on the CONN_LCD connector can be used.
      ;R = relative tolerance in %, default 20%
      ;E = minimum extrusion length before a commanded/measured comparison is done, default 3mm
        Are you running an old version of Duet Web Control?
        • claustro
          Thank you for answering me
          I found the solution in web control manual
          Added
          M106 P2 H-1 and now I can drive my leds 🙂
          thank you
