    Wifi Problem with Latest Firmware 2.02 RC3
    • Timon321
      Timon321 last edited by Timon321
      I accidentically hit a macro, that killed my wifi settings.
      Now i cant get the wifi connected again.
      In my configuration i commented the M552 S1 out.
      And with everything i try, with M552 i get this:
      WiFi module is being started
      With M587: Failed to retrieve network list
      I cant even delete my Network with M588.
      Failed to remove SSID from remembered list
      Where am i stuck?
      Here is an output of the M112:
      *=== Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9568A-F23SD-6JTDG-3SD6M-1UNZD
      Used output buffers: 1 of 20 (10 max)
      Static ram: 28532
      Dynamic ram: 98488 of which 0 recycled
      Exception stack ram used: 288
      Never used ram: 3764
      Tasks: NETWORK(ready,1872) HEAT(blocked,1232) MAIN(running,3564)
      Owned mutexes:
      Last reset 00:03:30 ago, cause: software
      Last software reset time unknown, reason: Heat task stuck, spinning module FilamentSensors, available RAM 3684 bytes (slot 3)
      Software reset code 0x00ad HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043d80f BFAR 0xe000ed38 SP 0x2000546c Task 0x4e49414d
      Stack: 00447489 0043c032 01000000 00000000 00000000 00000000 00000000 3e178897 3e1cd04f 41880000 3e3a37fb 3e63932a 3e924c1e 3c36f241 3eccd06f bdd86988 3f800000 c0a00000 00000000 60000010 0043c033 20002bb0 00432f63
      Error status: 0
      Free file entries: 10
      MCU temperature: min 42.4, current 42.7, max 42.9
      Supply voltage: min 0.6, current 0.6, max 0.6, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 298719687
      Slowest loop: 0.18ms; fastest: 0.06ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.18ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is starting
        WiFi module is disabled
        === Expansion ===
        ok*
      • Timon321
        Okay i solved my problem now.
        Forgot to flash the Firmware on the Wifi Module with M997 S1.
        Only flashed the main Firmware!
