    upgrade my tornado with my duet
    • mickey30mundefined
      mickey30m
      Hi
      i change my tarantula for a Tevo Tornado. now i want to upgrade my tornado with my Duet Wifi.
      I got almost everything working. but only my thermosistor stay on 2000c
      and when i change my homing files i dont have no bltouch any more.
      (maybe later)
      but when i home x the meaning is that he go to the swtitch and when hit go some mm back and again go to switch.
      now he go to the switch and dont do it a second time. only one time.
      this is my homex.g
      G91 ; relative mode
      G1 S2 Z4 F200 ; raise head to avoid dragging nozzle over the bed
      G1 S1 X-350 F3000 ; move up to 240mm in the -X direction, stopping if the homing switch is triggered
      G1 X4 F600 ; move slowly 4mm in the +X direction
      G1 S1 X-10 ; move slowly 10mm in the -X direction, stopping at the homing switch
      G1 S2 Z-4 F200 ; lower the head again
      G90 ; back to absolute mode
      home y is the same but change the x for y
      the same for y and z.
      z is also a limit switch.
      thanks
        mickey30m
        i have everything now working.
        now i need to calibrate everything
          mickey30m
          Now i want to add a tl-feeder from trianglelabs.
          But i get a error that no tool is selected.
            Phaedrux Moderator @mickey30m
            @mickey30m Check this out
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files
