    How to change print start point/coordinate system origin
    • PuddingBaer91undefined
      PuddingBaer91
      Hi there,
      i successfully upgraded to my new duet wifi and it is awesome. It is worth every Cent 😉
      Okay if i home my axes the Printer will move to the left front Corner where my endstops are. But for homing z it will move to the opposite corner (right back). Prints will also start from the right back corner. I found out that the coordinate System origin is the right back Corner. But for me it is better to match the coordinate System origin with endstop Position so zero is Zero (Logical). Is it possible to change the location? Is it also possible to let the Printer home z at another Location for example at the bed center?
      Thank you
        I'm glad you like the Duet! See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files and https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin, then ask again if you need to.
          PuddingBaer91
          Thank you. Wonder why i not found this. I already searched a lot and always found a solution?!?
          I will look into this and try
            Phaedrux Moderator @PuddingBaer91
            @puddingbaer91 This is also a good article to help visualize it.
            https://drmrehorst.blogspot.com/2017/08/setting-up-3d-printers-origin.html
              PuddingBaer91
              HAHA guys i found the problem i can't believe: I used the wrong motor directions so nothing worked logical, minus were plus and plus were minus Hääää??? oh my god 😄 now it works like it should.
