    5v rail?
    1243
    • someuniqname
      someuniqname last edited by
      hi,
      just about to install a new duet wifi v1.01…
      is it expected that the 5v and 3.3v leds are only on when the 5v rail gets external 5v via a psu/usb? i have 24v connected to vin and only see the vin (blue) led and i also have the feeling that the 5v and 3.3 v rails are not powered (no connect etc).
      btw i have the jumper INT_5V_EN set
      regards
      /uwe
      • InSanity
        InSanity last edited by
        You should be seeing 5v and 3.3v when powered from 12-24v and with the jumper in the correct spot. Sounds like something might be wrong.
        Edit: What do you get if you plug in USB ?
        Jeff
        Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
        • someuniqname
          with usb plugged i see 5v+3.3v leds on.
          • InSanity
            So your jumpers look like this https://duet3d.com/wiki/File:Power_internal_5V.jpg ?
            Jeff
            • someuniqname
              yes they look like this
                It sounds to me that either you don't have the internal 5V power jumper in place, or the 5V regulator on your board is faulty (which I don't think we have ever seen before).
                • someuniqname
                  where is the 5v regulator on the board?
                  i will send a few snaps in a minute
                  • InSanity
                    @someuniqname:
                    It's the little square A4403 chip next to the jumpers.
                    Jeff
                    • someuniqname
                      hahahahaha seems i earned this weekends looser price
                      for your entertainment: while upgrading i installed a fuse between psu and duet. that fuse is in a little box with an LED. actually the fuse should be in the box 🙂
                      essentially the duet got enough power to light the vin led but that was only what came via the addon led of the fuse. once i installed the fuse all is as expected 🙂
                      regards
                      • InSanity
                        @someuniqname:
                        regards
                        Ok, sorry but that is too funny.
                        Jeff
