    Max curent ampere on heather E0 and E1
    • flopo76undefined
      flopo76
      Hi,i have 3 cartridge on my hotend nozzle,i want to know max Amper output for heather E0 and E1.
      Thanks.
        They should be good to at least 6A if you use properly-crimped ferrules on the wires that you connect to them.
        • flopo76undefined
          flopo76
          Thank,for replay,but the mosfet on duet board support 6A ore more?
            Yes the mosfet will handle much more than 6A. The limiting component is likely to be the terminal block. A few 3.5mm terminal blocks are rated 6A, many are 10A, some are even higher.
