    Tevo Little Monster converstion - Endstop and Z height issue
    • Tef9undefined
      Tef9
      Hello all,
      My first post on this site. After reading about others conversion of the TLM I decided to go down the same route. I have to say this forum is packed full of info and it has helped me get up and running, a big thank you. Sadly I am stuck with just two problems and I am sure its simple and connected:
      1. When I home not all of the towers make it to the top, I am not sure why. A second home always fixes this problem but if the printer travels over any distance, its seems to be a little bit off. I don't move fast as a slow functional printer is preferable to a fast non functional one.
      2. When I try and print the printer seems to be set to the wrong Z height, to the point I feel the motors could be skipping steps. I did run the test and as I am using a BLTouch. Just to say I read the wiki and the external post regarding that sensor and how to check and set the height.
      This makes me wonder if I am skipping steps, could be another problem but I am at a loss - being so close to finishing the printer any help would be greatly appreciated. ☺
      Files posted below.
      Best regards,
      Andy
      Config.g
      ; Configuration file for Duet Ethernet (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R157 L397.1073 B200 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      M557 R130 S20 ; Define mesh grid
      ; BL-Touch
      M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
      M558 P9 H5 F200 T5000 ;P9 is a key BLTouch Value
      G31 P25 X0 Y0 Z3.78 ; Set Z probe trigger value, offset and trigger height
      M557 R150 545
      M350 E32 I0 ; Configure microstepping without interpolation
      M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E837 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S285 ; Set maximum heater temperature to 285C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M563 P0 D0 H1 ; Define tool 0
      M550 PTEVO Little Monster ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      Bed.g
      ; bed.g
      ; called to perform automatic delta calibration via G32
      G28
      ; Clear any bed transform
      M561
      ; Probe the bed at 6 peripheral and 0 halfway points, and perform 3-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      M98 Pdeployprobe.g
      G30 P0 X0 Y129.9 H0 Z-99999
      G30 P1 X112.5 Y64.95 H0 Z-99999
      G30 P2 X112.5 Y-64.95 H0 Z-99999
      G30 P3 X0 Y-129.9 H0 Z-99999
      G30 P4 X-112.5 Y-64.95 H0 Z-99999
      G30 P5 X-112.5 Y64.95 H0 Z-99999
      G30 P6 X0 Y0 H0 Z-99999 S3
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      M98 Pretractprobe.g
      G1 X0 Y0 Z150 F1500
      G29
      G1 X0 Y0 Z150 F1500
      RetractProbe.g
      M280 P3 S90 I1
      HomeDelta.g
      ; homedelta.g
      ; Use relative positioning
      G91
      ; Move all towers to the high end stopping at the endstops (first pass)
      G1 X505 Y505 Z505 F1500 S1
      ; Go down a few mm
      G1 X-5 Y-5 Z-5 F1500 S2
      ; Move all towers up once more (second pass)
      G1 X10 Y10 Z10 F360 S1
      ; Move down a few mm so that the nozzle can be centred
      G1 Z-5 F2000
      ; Switch back to absolute positioning and go to the centre
      G90
      G1 X0 Y0 F2000
      DeployProbe.g
      M280 P3 S160 I1
      M280 P3 S10 I1
        @Tef9, welcome to the forum!
        Your homing issue is covered in the FAQ page in the Troubleshooting section of the documentation.
        You have the maximum speeds set very high in your M203 command. Try reducing the XYZ maximum speeds to 12000 and see if that fixes the missed steps.
        • Tef9undefined
          Tef9
          Hi There,
          Thank you for the reply. Although the speed was set high this was not the issue. The issue lay in the homedelta.g file, I set each axis to 505 instead of 520. All working fine, I have another question, but will post separately. 🙂
          Best.
          Andy
