    Constant Axis limits message
    • boldnuts
      boldnuts last edited by boldnuts
      Hi Guys, I am getting a constant axis limits message when printing on my TLM Delta
      11:05:45Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
      11:05:44Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
      11:05:42Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
      11:05:41M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6J1F4-3SD6R-TJTBM
      Used output buffers: 3 of 20 (14 max)
      Static ram: 28532
      Dynamic ram: 98664 of which 0 recycled
      Exception stack ram used: 440
      Never used ram: 3436
      Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,552)
      Owned mutexes: WiFi(NETWORK)
      Last reset 02:05:59 ago, cause: power up
      Last software reset at 2018-10-26 14:19, reason: User, spinning module GCodes, available RAM 3460 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 256.7ms, max retries 0
      MCU temperature: min 13.3, current 32.8, max 33.2
      Supply voltage: min 23.8, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max 0/161
      Driver 1: ok, SG min/max 0/173
      Driver 2: ok, SG min/max 0/175
      Driver 3: ok, SG min/max 0/1023
      Date/time: 2018-10-29 11:05:40
      Slowest loop: 125.75ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 127, MinFreeDm: 120, MaxWait: 397237ms, Underruns: 0, 0
      Scheduled moves: 212968, completed moves: 212938
      Bed compensation in use: mesh
      Bed probe heights: 0.143 0.018 0.160 0.099 0.056
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.9
      Segments left: 1
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X-14.571 Y8.168 E0.0135" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 258.76ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 2c:3a:e8:0b:16:4f
        WiFi Vcc 3.31, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15816
        WiFi IP address 192.168.1.5
        WiFi signal strength -43dBm, reconnections 0, sleep mode modem
        === Filament sensors ===
        Extruder 0 sensor: ok
        === Expansion ===
        11:05:40Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:39Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:37Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:36Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:35Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:34Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:32Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
        11:05:25Axis limits X-155.0:155.0, Y-155.0:155.0, Z0.0:519.5
      I have not changed any settings since flashing the latest firmware, bug or setting issue?
      Config.g
      ; generated by RepRapFirmware Configuration Tool on Sat Jan 27 2018 18:46:34 GMT+0000 (GMT Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Configure automatic saving on power loss
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 L400.360 R173.614 H519.461 B155.0 X-0.115 Y0.019 Z0.000
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P8 R0.4 H5 F1200 T10000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.099 ; Set Z probe trigger value, offset and trigger height, INCREASE VALUE WILL LOWER NOZZLE CLOSER TO THE BED, DECREASE THIS VALUE WILL RAISE THE NOZZLE FROM THE BED
      M557 R150 S30 ; Define mesh grid
      M569 P0 S1 ; Drive 0 goes forwards (x motor)
      M569 P1 S1 ; Drive 1 goes forwards (y motor)
      M569 P2 S1 ; Drive 2 goes forwards (z motor)
      M569 P3 S1 ; Drive 3 goes forwards (extruder 0)
      M92 X160 Y160 Z160 ; Set drive motor steps per mm
      M92 E2680 ; Set extruder steps per mm
      M566 X300 Y300 Z300 E40 ; Set maximum instantaneous speed changes (mm/min)Jerk
      M203 X6600 Y6600 Z6600 E1000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M593 F20.5 ; cancel ringing at 40.5Hz
      M572 D0 S0.010 ; pressure advance
      M207 S0.9 R0 F2000 ; firmware retraction
      M208 S0 F600 ; set retraction recover speed / adjustments
      M376 H10 ; Set bed compensation taper
      M301 H0 S1.00 P10 I0.1 D200 T0.4 ; Use PID on bed heater (may require further tuning)
      ;M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0 - BED HEATER
      M305 P0 T100000 B4607 C8.950070e-8 R4700 ; BED : Set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; Set temperature limit for heater 0 to 150C - BED HEATER
      ;Hotend
      ;M307 H1 A373.1, C293.9, D40 S1 ; PID settings
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 F0 ; Define tool 0
      T0 ; select first hot end</redacted>
      M550 PTEVO Little Monster ; Set machine name
      M552 S1 ; Enable network
      ;M587 S"Home" P"" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off - PRINT FAN
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on - NOZZLE FAN
      M106 P2 S1 I0 F500 H100:101 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on - PCB/Drive Motor CASE FAN
      ; Filament Out Sensor
      M591 D0 P1 C3 R20 S1 ; configure extruder drive 0 to use E0 endstop (C3)
      M591 D0 ; display filament sensor parameters for extruder drive 0
      M912 P0 S-11.7 ; Set CPU temperature sensor offset
      M501 ; Load settings from Config_override.g file on boot
      config-overide.g
      ; Delta parameters
      M666 X-1.216 Y-0.768 Z1.984 A0.19 B0.69
      ; Heater model parameters
      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
      M301 H0 P10.0 I0.100 D200.0
      M307 H1 A281.9 C186.6 D3.6 S1.00 V23.9 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        My guess is that your GCode file contains M208 commands. Can you check that?
        • boldnuts
          Hi dc42, Yes that's correct, I am using this
          I will edit it correctly, thanks
