    Problem building RRFLibraries
    Firmware developers
    • felix9tundefined
      felix9t
      Hi there! Can anyone help me? I am trying to build the Firmware for DUET Ethernet but I cannot build RRFLibraries (Mac). All other packages work (except RepRapFirmware of course..) The following errors occurs every time:
      Looking forward to your answers 🙂
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @felix9t
        @felix9t CoreNG is another project in dc42's repository which is referenced by the RRFLibraries project. I would use the latest RRFlibraries branch and the v2-dev branch of CoreNG.
        Rename the project name to CoreNG if it has a different name. Then the path should be found. ../.. means go up two levels in the path, so CoreNG must be in the same Eclipse workspace as the RRFLibraries project to be found.
        I would build CoreNG first and make sure it compiles correctly, before rebuilding the RRFLibraries.
        • felix9tundefined
          felix9t
          Thanks! I had the wrong version of CoreNG..
          • felix9tundefined
            felix9t
            Unfortunately now I have a different problem (Sorry that I ask these 'beginner questions'.. I'm new to this project..):
            I can complie all packages except the RepRapFirmware. I always get these errors and the build fails:
            • felix9tundefined
              felix9t
              Alright solved it. Was using the wrong build of RepRapFirmware..
              • JoergS5undefined
                JoergS5 @felix9t
                @felix9t I have fallen over these things in the beginning too!
