Duet2Wifi Heatbed Mosfet no Gate Signal
  • Hello there,
    Machine Setup is the following:
    Vin: 24V
    Heatbed Current Max: 11A (Switched on the High side)
    Heater Config:
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    FW:
    Electronic: Duet WiFi 1.02 or later
    Version: 1.21 (2018-03-21)
    Wifi Server: 1.21RC4(08b3)
    Web Interface: 1.21-RC4
    I just finished installing my Duet 2 Wifi.
    Problem is that the Heatbed is not Heating up, first i measured the Voltage Across the Terminals, that turned out to be a constant 24V (also when bedheating was on 55°C).
    Then i measured the Gate Voltage on R20 as well as the Gate of the Mosfet (Infineon IPD036N04L G).
    Both Turned out to be 0V.
    The Heatbed Led is constantly On during all tests (makes sense when the Mosfet isn´t switching).
    Seems to me that the PWM-Signal of the Micro isn´t reaching the Mosfet...
    Any Ideas on how to fix this?
    Sincerely,
    Slaycrit
    @slaycrit said in Duet2Wifi Heatbed Mosfet no Gate Signal:
    Please explain "Switched on the high side". Does this mean you are using an external SSR or mosfet to switch the bed heater? If so, how have you connected it to the Duet?
  • @dc42 I am using the Internal Mosfet, +24V are connected to VIN of the Heatbed Terminal, V+ of the Heatbed is connected to the other Side of the Teminal.
    The Heatbed then has its V- connected directly to Ground.
    But the thing I am really concerned with, is the missing Gate Signal.
    That's not the correct wiring. The bed heater gets its power from the main VIN terminal. So you need to connect the power supply just to the VIN terminal block, and the bed heater to the bed heater terminal block. Try that and see if it works.
    There is a different wiring scheme if you are using a separate PSU for the bed heater, but that's not what you have described.
  • @dc42 Thank you, that pointed me into the right direction.
    I tried to use a different circuit for the Heatbed as the Main Vin of the board has a 6A Breaker.
    The Heatbed is now switched externally by a separate Mosfet, this works perfectly, also directs some of the High Current Stuff away from the Duet.
