    Filament monitor reported to much movment
    Filament Monitor
    • claustro
      claustro last edited by
      I have a magnetic filament monitor which run smoothly form almost a yeat and many prints, but lately I am receiving this error How can I get rid of it. The print run smoothly and everything seems ok so even after resuming the print.
      • claustro
        Iam trying to investigate the cause of this error.
        I did a M591 D0 R-1
        but my value are a lot worse then before .
        now I have
        Duet3D rotating magnet filament monitor on endstop input 3, enabled, sensitivity 28.80mm/rev, allowed movement 0% to 160%, check every 3.0mm, current position 255.2, measured sensitivity 23.05mm/rev, measured minimum 114%, maximum 135% over 39.4mm
        last time a did a check tolerance +12% -9%
        Can someone explain me this value?
        thx
        Andrea
          Could it be that the magnet on the rotating shaft is no longer aligned with the centre of the sensor chip?
          • claustro
            Thank you for answering me .
            I cleaned and checked the sensor and it seems fine.
            The starnge things , for me is that minimum and maximum are over 100% but the variation is still low
            measured minimum 119%, maximum 136% so 17%.
            I can't undestand why before I had always a variation of about 30% but -10% +20%
