Movement is stuttering. Appears to slow printing down
@nophead said in Movement is stuttering. Appears to slow printing down:
@asdasd1234 Do you have control over the number of line segments in the STL file? I have noticed with Cura it will generate ridiculously short segments if the model has them. As I model in OpenSCAD I can simply set $fs to half my extrusion width and then I don't get any segments shorter than 0.25mm. There really isn't any point in printing shorter segments. Skeinforge combines segments that are too small, not sure about other slicers.
Not that I'm aware of. I use fusion 360 for all my parts. The options I get are on this link (https://i.imgur.com/iWAnnjO.png) . All the refinement option does is change the normal/surface deviations.
@asdasd1234 , I have delved into Cura some more and now I think that the problem is actually being caused by the buggy wall overlap compensation and not the clipper lib. So, a simple change for you to try would be to disable the overlap compensation and see what happens. I actually use a modified version of that code because the original is so buggy but it still has problems so it doesn't surprise me that it is generating the spurious short line segments.
I am homing in on the bug(s) but do not yet have a fix.
Another workaround is to set the line width to 0.39 and set fill gaps between walls to nowhere.
I've just tested the firmware using this script:
G10 P0 S200 M116 G1 X-20 Y0 Z50 F6000 ; start extruding g1 x0 e1 f3000 g1 x2 e0.1 g1 x22 e1 g1 x22.2 e0.01 g1 x42.2 e1 g1 x42.22 e0.001 g1 x62.22 e1 g1 x62.24 e0.001 g1 x82.24 e1 g1 x82.242 e0.0001 g1 102.242 e1
The moves are all designed to have constant extrusion rate from one to the next. Running this test I get no stuttering, with pressure advance set to 0.2 or 0.4.
If I am to attempt a fix in firmware then I need an example of a gcode sequence that causes the stuttering. Preferably, also an analysis (perhaps on a spreadsheet) of:
- What the extrusion rate is for each segment;
- What the movement direction is for each segment
Has it been established yet whether the problem still occurs with zero pressure advance?
PS - the post by @burtoogle 3 Nov 2018, 13:27 includes an image that shows an example, but I can't copy and paste from that.
PPS adding 0.1mm of Y movement to the 20mm long moves makes no difference, still no stuttering.
I'll run a print today without the pressure advance and let you know if still stuttering and will supply the gcode file, thanks
EDIT: Will have to be tomorrow now, I'm out in a bit and wont have time.
EDIT: Ran out of time again, hopefully get some gcode examples up today (12th)
I've submitted a small fix to the Cura devs that stops the small line segments being created when you have curved walls lying immediately adjacent to each other and the overlap compensation is enabled. It should fix the project discussed above but doesn't really tackle the underlying problems that the overlap compensation has. Fixes are currently taking many months to get merged into Cura (assuming it is accepted) so don't expect the official releases to have this anytime soon. The next development version that I release will have this fix in it. See https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
