    duet3d wifi 205 command is not supported
    1.0k
    • trout thugundefined
      trout thug
      Ok so I can get heat to the delta and I can probe all around and get values. I wanted to do a test cube and I get the following error 205 command is not supported. I'm using cura (the newest version), newest firmware, and duet wifi. I also heard some strange noises coming from my delta. I hope I'm getting closer but I'm glad I can get the heater to work and the smart effector to also work.
      So close to printing I can taste it,
      Bill in colorado
      CR10S works great, Delta printer by Gear Rev - which is terrible- with starting to set up Duet Wifi and Smart Effector and hoping that I can get it to print something that isn't terrible.
        I presume the message was actually "M205 command not supported". You can ignore the message. However, i don't think it should be generated if you set the GCode flavour in Cura to RepRapFirmware.
