    Sensorless homing X axis going the wrong way sporadically
    1.5k
    • minimundefined
      minim
      The problem is similar to the one in this post but the thread was locked so I'll try again here : https://forum.duet3d.com/topic/4830/sensorless-homing-oddness/14
      I have a core xy with 400x400mm movement. The Probe scripts works sometimes but often the X axis is going the wrong direction and it ends up crashing. I've tried to increase the current up to 100% but it still wanders off to X minus when everything is set for X positive. Anyone else had this problem?
      This is in the config.g file:
      M574 X2 Y1 Z0 S3
      M584 X0 Y1 Z2:5:6 E3:4
      M915 P0:1 S5 R1
      and this is in my X home script:
      M0 ; make sure everything has stopped before we make changes
      M913 X100 Y100 ; reduce motor current to 50% to prevent belts slipping
      G91 ; use relative positioning
      G1 S1 X500 F2410 ; move all carriages up 500mm, stopping at the endstop
      G90 ; back to absolute positioning
      M400 ; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 ; motor currents back to normal
      G1 X1 F5000 ; centre the head and set a reasonable feed rate
      M400 ;wait for current moves to finnish
      G92 X0 ; giving 1mm clearance on bumpstop.
      The steppers are 42BYGHW804 1.8degree, 3.6V/1.2A, resistance 3ohm, 5mH inductance, 4800G.cm holding torque
      Firmware Electronics: Duet WiFi 1.0 or 1.01 + DueX2
      Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.4-b1
      https://lokalhost.org/3d/homex.txt <-- homex.g
      https://lokalhost.org/3d/config.txt <-- config.g
      Edit:
      Now when I lower current to 20% I can always home to correct direction on the first "Home X" after i reset the printer. The second time it always goes the wrong way. I also tried a M18 to "release" the X home position but it still goes the wrong way.
        What I think is happening is that when you send the G1 S1 X command to do the homing move, sometimes the stall flag is already set. Try doing a G1 S2 Xnn Ynn Fxxx move immediately before that G1 S1 move, to enable the motors and clear the stall flag. Choose a positive or negative value of nn so that the move is at least 2 full steps long.
        Alternatively, after the G1 S1 X move, back off a few mm and repeat it.
        • minimundefined
          minim
          Is there any way to check if the stall flag is set? Now I home it and then I move the X axis to center of axis just so I have time to stop it if it goes the wrong way so it shouldn’t be stalling. So it’s not like it’s stopped at the end stop or anything.
          If it’s a feature and not a bug I can’t really use sensorless homing as it’s not fun watching your printer go by random in and hammer on the wrong end of the axis without stopping 😛
          It works perfect now that I know I have to reset my printer with the emergency button before homing. If I try to home after home has been set it always goes the wrong way and hammer on the axis until I’m able to stop it.
            Did you try my suggestions?
            • minimundefined
              minim
              Yes I tried it now. I added G1 S2 X2 Y2 F500 upfront and it works as a workaround but how can I see if the stall flag is set? Can I make it a condition in the home code somehow?
                The M122 command reports the motor status, including stall.
                • minimundefined
                  minim
                  I'll do some testing with this later tonight. If this is the case could I suggest for later releases to just throw a homing error if it detects a stall at the start of homing? It's easy to break stuff when it suddenly goes hard into the wrong side without stopping upon stall. The sensorless homing is awesome when it works 😄
                  • minimundefined
                    minim
                    After a X homeing + moving it +50 on the jog buttons.
                    Driver 0: standstill, SG min/max 328/1023
                    Driver 1: standstill, SG min/max 308/1023
                    Driver 5: standstill, SG min/max not available
                    Driver 6: standstill, SG min/max not available
                    Expansion motor(s) stall indication: yes
                    After executing G1 X2 F200
                    I assume that min/max is related to stall? This is the only difference I Can find in the M122 command.
                      The min/max is the min and max readouts of the stallguard register since you last ran M122. The values for other drives are not available because you haven't moved them yet.
